minipov usb port com1 help
by stevenl1 on Fri Jun 11, 2010 1:09 am
FIRST: Are you using a Minipov3 from a kit or from DIY? Make sure you mention that in your post
Minipov3 from ladyada.net
SECOND: What OS and computer are you using?
Windows 7 on a Macbook Pro (Dual boot, I can use either OS for this project, I am going for Windows though)
THIRD: Are you using a USB adapter or a serial port?
I am using the USB adapter that was suggested from ladyada.net
FOURTH: Did the minipov light up at all when you turned it on?
Yes, it is running through the lights one by one as I type.
FIFTH: What -specifically- isn't working?
I followed the instructions http://www.ladyada.net/make/minipov3/solder.html perfectly.
Default light cycle is working.
I followed the instructions http://ladyada.net/make/minipov3/software.html but got stuck.
I dont know what to call my minipov, I dont have a com1 or anything like that.
I can't figure out what my device is located. I don't have any Com1. And, where is normally shows it I have "Other devices" sub directory "USB2.0-Serial"
SIXTH: Post screenshots (NOT copy&paste) of what is happening
let me see here...
SEVENTH: Post clear, in-focus, not-blurry, easy to see photos of the top and bottom of the kit. If the photos are blurry, unfocused, and difficult to see they will only make it harder to debug what is going on
I dont have camera, but the minipov is working perfectly.
Please help! <3
minipov ports.png (57.82 KiB) Viewed 6185 times
stevenl1
Re: minipov usb port com1 help
by adafruit_support_bill on Fri Jun 11, 2010 5:47 am
There is a yellow flag indicating a problem of some kind with your "USB2.0-Serial" device. Most likely it couldn't locate the driver for it. That's why there is no COM port.
by stevenl1 on Fri Jun 11, 2010 9:11 am
Interesting, I did install the driver that was specifically for this usb that is also supposed to work with the minipov.
I got the usb converter and the driver link from http://www.adafruit.com/index.php?main_ ... ucts_id=18
I wonder what I can do.
stevenl1
by adafruit_support_bill on Fri Jun 11, 2010 9:18 am
Try right-clicking on the device in the device manager and see if it will give you a more specific error.
If it is a driver problem, it should give you the option to re-install the driver from a specific location.
I have heard that Windows 7 is a little more finicky with reagard to drivers, but I don't have any first-hand experience.
by oPossum on Fri Jun 11, 2010 9:56 am
Check the VID/PID. It may need a different driver.
viewtopic.php?p=79065#p79065
I am the Possum, and I approve of this message. Sent from MacBook Wheel Sorry for my bad German.
oPossum
by stevenl1 on Fri Jun 11, 2010 3:52 pm
Under hardware IDs it show the following.
VID_1A86&PID_7523&REV_0252
VID_1A86&PID_752
I am still unable to find the correct driver.
The USB2.0 to RS232 converter did come with a mini writable disk with no information. My problem is that my macbook pro does not take mini disks :/ so have to find the driver online.
stevenl1
by stevenl1 on Fri Jun 11, 2010 5:35 pm
I did try the driver from http://www.winchiphead.com/download/CH341/CH341SER.ZIP but it in German I think and the driver is completely confusing. Can anyone one help with that maybe?
I was able to get my desktop to turn on to try and see if i could make an iso or something. But, it could not copy it. So then I just tried to install it, but it is corrupted! That irritates me because it came with the USBtoSERIAL from ladyada site.
I cant find a working driver online, can anyone help!
stevenl1
by adafruit on Sun Jun 13, 2010 12:57 pm
hi please don't post in multiple threads - it makes it hard to help you if the information is in 5 places!
by konnyaro on Thu Jul 08, 2010 11:06 pm
konnyaro
