Non-responsive MiniPOV4.
by nicklalic on Thu Jan 16, 2020 9:52 pm
I recently purchased and assembled the MiniPOV4 (Jan/2020). Unfortunately when I power it on nothing happens: none of the LEDs blink, and there is no other indication that anything is happening.
Following the suggestions found in the forum, I tried a number of things:
  • visually inspected the solder work for any issues (see attached)
  • used new batteries and measured their voltage
  • measured a voltage from the batteries to the board when in the ON position
  • measured the voltage on Pin 7 of the socket to make sure that the IC is powered (it is).
  • plugged it in to the USB port but did not see the device register (running MacOS 10.14.6 Mojave).
I'm not sure what else to check. I'm open to suggestions.
- Nick
nicklalic
Re: Non-responsive MiniPOV4.
by mikeysklar on Thu Jan 16, 2020 10:11 pm
The component placement and soldering look good. I think you are close especially since the voltages are showing up correctly.
I'm surprised about the MiniPov4 not showing up on your mac connected through a hub. It is a 2.0 USB hub? Do you have the battery pack turned on and connected while connected to the computer (this is necessary).
mikeysklar
by nicklalic on Thu Jan 16, 2020 10:38 pm
Hi Mike,
Thanks for the tips.
I tried it both through a hub (usb 2.0) and directly into my iMac. In both scenarios the device does not show up in the list of USB devices from macOS.
I've read elsewhere that this can point to the Atmel chip being unprogrammed, since that is what does the work of presenting itself as a USB device. I'm not sure.
nicklalic
by mikeysklar on Fri Jan 17, 2020 6:57 pm
Well, let's start with the obvious risk which is some of the solder points could use a little more flow through. Just go over each soldered joint again briefly and see if the behavior changes at all. With kits like this that is the most common issue and it is unlikely we would have shipped you an unprogrammed chip.
mikeysklar
by adafruit_support_carter on Sat Jan 18, 2020 1:23 pm
Do you still have the bag it came in with the white sticker with a barcode on it? If so, can you send us a photo of that please. That will help us track down what might have happened. Thanks!
by nicklalic on Mon Jan 27, 2020 6:11 pm
I do still have it.
Here it is:
Thank you!
nicklalic
by nicklalic on Mon Jan 27, 2020 6:16 pm
@mikeysklar After looking at the solder points under a microscope, I see what you are saying. I'll try to reflow the suspected solder points and see if it helps.
nicklalic
by adafruit_support_carter on Mon Jan 27, 2020 6:23 pm
Hey @nicklalic - Thanks for the photo. Let's just send you a new chip. Send an email to support@adafruit.com with a link to this thread and they can take care of you from there. Sorry your POV arrived non-functional.
by nicklalic on Mon Jan 27, 2020 9:23 pm
Thank you!
nicklalic
