minipov3 wont blink anymore
by stavi24 on Fri Jul 23, 2010 12:05 am
ok so i purchased the minipov kit and put it all together and it flashed the sequence like it was supposed to, but when i plugged it in and tried to install the firmware it kept failing. i have a serial pci card on my computer and it is running vista. when i first plugged it in the sequenced lights stop. i found the com port turned on the kit and when i start the programming it gives me the following.
avrdude -p attiny2313 -P com3 -c dasa -U flash:w:minipov.hex
avrdude: AVR device not responding
Double check connections and try again, or use -F to override this check
avrdude done. Thank you.
make: *** [program-minipov] Error 1
when i would give the make command it would blink the 3 furthers leds from the connector once. i unplugged the kit and the sequencing started again i plugged it back in and trying multiple times getting the same error but when i unplugged it again now there is no sequencing, did i somehow toast the ic?
2010-07-22 22.19.17.jpg (58.74 KiB) Viewed 2135 times
2010-07-22 22.18.42.jpg (61.14 KiB) Viewed 2135 times
stavi24
Re: minipov3 wont blink anymore
by adafruit_support_bill on Fri Jul 23, 2010 6:11 am
Looks like a good job on the assembly. Do you have the MiniPOV powered up when you connect it to the COM port?
by stavi24 on Sat Jul 24, 2010 2:57 pm
yes i have tried powered on then connect and connect then power on and no difference either way
stavi24
by mtbf0 on Sun Jul 25, 2010 7:33 pm
check the solder on the serial connector. takes a while to heat up those pins and you could have some cold joints
mtbf0
