Kit as LED cube not seen by serial port
by boredboy on Fri Sep 17, 2010 11:20 am
I have built an LED cube using the minipov kit. The test program that was preloaded on the chip works fine. I think all my solder joints are good. I am connecting directly to a serial port, but it is not being seen. Would the LED's light if there were a problem with any of the components? I am a noob, so how would I check them?
boredboy
Re: Kit as LED cube not seen by serial port
by adafruit_support_bill on Fri Sep 17, 2010 11:30 am
Is the board powered on when you connect it? It needs to be on for programming.
If you have followed all the steps here http://www.ladyada.net/make/minipov3/software.html and it still doesn't work, post some clear photos of the front & back of the board.
by boredboy on Fri Sep 17, 2010 11:50 am
Thanks for the very fast response. It is powered on.
This is what I get
C:\>make program-ledcube
avrdude -p attiny2313 -P com1 -c dasa -U flash:w:ledcube.hex
avrdude: AVR device not responding
this check.
avrdude done. Thank you.
make: *** [program-ledcube] Error 1
I will post photos as soon s i can get them taken
boredboy
by adafruit_support_bill on Fri Sep 17, 2010 11:57 am
Other details that might be helpful:
Operating System?
Regular serial port, or USB/Serial adapter?
by boredboy on Fri Sep 17, 2010 12:17 pm
XP on 2 different machines. Same result. regular serial port
boredboy
by boredboy on Fri Sep 17, 2010 2:30 pm
Would the cube still work, like mine does, if all the solder joints or components were not good?
boredboy
by adafruit_support_bill on Fri Sep 17, 2010 3:14 pm
If the only bad solder joints were between the serial connector and the microprocessor, it would work just fine.
by boredboy on Sat Sep 18, 2010 2:10 pm
Here are the pics
boredboy
by adafruit_support_bill on Sat Sep 18, 2010 4:39 pm
Pin 4 on the top looks like it might be a cold joint. Those RS-232 pins need a good hot iron.
by boredboy on Mon Sep 20, 2010 11:36 pm
Thanks. I think I have resoldered every joint now and it still is not recognized. Any other advice?
boredboy
by adafruit_support_bill on Tue Sep 21, 2010 5:47 am
Do you have the correct COM port configured in the makefile?
What settings do you have on the COM port? Speed, data bits, stop bits and flow control?
by boredboy on Tue Sep 21, 2010 11:16 am
I believe so. It was originally set to com8 and gave a different error when I tried to connect so I set it to com1. I am pretty sure the settings are all default, 9600, 8 bits, no parity, 1 stop bit, no flow control
boredboy
by boredboy on Fri Sep 24, 2010 11:40 am
Do any changes need to be made to the port settings? I am still not having any luck
boredboy
by adafruit_support_bill on Fri Sep 24, 2010 11:57 am
Those are the same settings I use to talk to my minipov.
Have you used the COM port to talk to any other serial device?
by boredboy on Fri Sep 24, 2010 1:59 pm
No, this is the only device I have tried. I did try it on 2 different machines with the same results.
I want to get a mini pov kit as well, but would like to work before that.
boredboy
