what pattern is preprogrammed into the miniPOV?
by mightyohm on Sun Oct 17, 2010 11:19 pm
I have noticed that miniPOV3's I have built at various times and from different sources have come with different pre-programmed patterns.
I have seen:
Make! (or was it Make:?)
Lighting one LED at a time, slowly.
What are kits programmed with now? Do kits sold in the Maker Shed come with a different pattern than kits sold direct?
Jeff
mightyohm
Re: what pattern is preprogrammed into the miniPOV?
by mitpatterson on Mon Oct 18, 2010 12:37 am
The ones direct from Adafruit just have the leds blink in order, to get anything pre-programmed you have to buy it from a place that sells them as they, such as Maker Shed. But its not hard to program your own, so it shouldn't matter whats on it, ladyada has a great tutorial (as usual) on how to do so, and someone made an app that all you have to do is type in text or select the areas you want lit and it will white the hex file for you.
mitpatterson
by mightyohm on Mon Oct 18, 2010 12:46 am
Yes, I understand it is easy to reprogram, I am asking because I need clarification for a book I am co-authoring that includes the miniPOV3. :D
I think my experience matches yours. Adafruit - blink in order. Maker Shed - preprogrammed message.
mightyohm
by adafruit on Mon Oct 18, 2010 12:53 pm
it depends a little. usually the adafruit ones just blink one after another - sometimes for resellers they request other designs but if they're in a rush they get the test pattern
