I had a thought, after reading about the laser projector on Hack A Day:
Why not make a POV with Lasers?
I'm not sure what the power requirements are for laser diodes, but I just thought it would be neat. You could display your image on any flat surface, from a reasonable distance.
Just a thought I had. Every day we get a little bit closer to my dream: having frickin' sharks with frickin' laser beams attached to their frickin' heads! And PIC on earth.
Laser POV
Possible
Started building one using an old harddisk and spinning the platter with a mirror on top, at a constant speed to allow the laser beam to 'scan' across the wall for X axis.
The w/r arm obviously moves another mirror on the Y axis, so you can create o-scope images on the wall.
To go POV with it:
To get some accuracy on it, control for the beam on/off and the usual RPM detect (beam break) on the platter. So a PIC or AVR can do the work here.
If you can scan quickly enough to generate a square blob on the wall, your virtually there. Workout the lines you have then on every line, turn your laser on/off at the points you want the image.
Tada! - crude television, with a laser instead of cathode ray.
To go POV with it:
There's this one http://cscott.net/Projects/FabClass/3/ and another laser/spinning mirror/clock project out there that I can't find at the moment.
not exactly the same thing, but ...
There are some people who are really into home-brew laser displays -- they
even build their own galvanometers! For instance, check out:
http://elm-chan.org/works/vlp/report_e.html
http://www.joeyhagedorn.com/v/electronics/Lasergalvo/
- guess_whoǃ
Laser POV? Like this one?http://web.media.mit.edu/~stefanm/TinyP ... ok_01.html
Re: Laser POV
Looks like Sony's gonna come to market with this.
http://www.engadget.com/2010/02/03/sony ... s-compact/
