Minipov3 Programming Issue
by chethandsome on Fri May 16, 2008 10:42 pm
Gotten up to running make mypov.hex but getting the following error
make (e=2): the system cannot find the file specified.
make: *** [mypov.o] Error 2
Any help mucho appreciated.
Retried a few steps after seeing things were in the incorrect folders, now got
Error 1, but still relates to the make program looking for
mypov.o, which doesn't exist.
chethandsome
by adafruit on Sun May 18, 2008 1:04 pm
can you compile -any- of the sources?
what OS, avr dev tools, etc are you using?
by chethandsome on Sun May 18, 2008 7:30 pm
OS - XP sp2
avrdude
I followed the instructions from the site to a "t" but can't get anything to compile.
chethandsome
by adafruit on Sun May 18, 2008 10:59 pm
post a screenshot of you tring to compile the code
do a 'dir' command beforehand so i can see all the files
by chethandsome on Mon May 19, 2008 6:36 pm
Here is a screen grab of the contents of the folder and the error when I try to compile.
I had to move the make.exe to the same folder as the rest of the source, as when I attempted to just run make as a standalone command, it wasn't able to find it. (not sure if that means a botched avrdude install or not).
chethandsome
by The_Don125 on Mon May 19, 2008 6:54 pm
try the command
make program-mypov
The_Don125
by chethandsome on Mon May 19, 2008 6:56 pm
i am getting the same error
chethandsome
by The_Don125 on Mon May 19, 2008 7:05 pm
Maybe try removing the file "make.exe"? I've never had that in my minipov3 directory, and I've been able to program fine. Maybe its causing problems with the make command, not sure.
The_Don125
by chethandsome on Mon May 19, 2008 7:15 pm
when it is moved out of that directory it won't find the executable from the command line and fails saying that 'make' is not recognized as an internal or external command, blah blah blah.
any idea what the mypov.o (or what ever source is being compiled) file and why is it being referenced?
chethandsome
by adafruit on Tue May 20, 2008 1:49 am
did you install winavr as the instructions say ?
you should not end up with make.exe in your directory
by chethandsome on Tue May 20, 2008 7:37 pm
went back reinstalled avrdude and now up and running!!!!!
thanks!!!!!
chethandsome
Re: Minipov3 Programming Issue
by EdEstes on Thu Aug 19, 2010 10:03 pm
I had a similar issue. It turns out the dos window I had open was before the installation, so the path wasn't correct. I closed the dos window, opened a new one and it had all the correct variables/paths so the code was able to compile.
--Ed
EdEstes
