๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday October 14, 2019 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday October 11 will go out Tuesday October 15 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
Programmed once, but wont let me do it again.
by Vestibule Chaperone on Thu Aug 07, 2008 4:35 am
I programmed the firmware once from the stock slm.hex, (it took eons to write it to the microcontreller - 10 minutes?!) and it went through the 14-minute sequence, sound, video, the worlds revealed behind closed eyelids...but that's where the fun stopped.
When I write my own sequences and just replace it with slm.c and compile it again, it tells me some nasty:
avrdude: Device signature = 0x1e910a
avrdude: safemode: Verify error - unable to read lfuse properly. Programmer may not be reliable.
avrdude: safemode: To protect your AVR the programming will be aborted
avrdude done.  Thank you.
or, after I eradicated and reinstalled the pl2303 for Mac OS 10.5:
avrdude: Device signature = 0x000102
avrdude: Expected signature for ATtiny2313 is 1E 91 0A
         Double check chip, or use -F to override this check.
Not as nasty, but the result's same. It reads fine, then wont program. Help appreciated in advance! Programming for a long time binaural beat listener (Hemi-Sync, Brainwave Mind Voyages for about 3 years) this would be a real treat...if I can get it working.
Vestibule Chaperone
by Vestibule Chaperone on Tue Aug 12, 2008 3:23 am
I had another chip from a previous controller that me and a friend put together but due to poor (more like non-existent actually) soldering abilities, lets just say it's put aside till latter use. But anyways, I took the chip from it and was able to initiate and program the chip with a sequence I wrote.
--ONCE--.
And now it's doing the exact same thing!
edit: Correction, not the exact same:
valentin-burovs-macbook:slm VaBur$ avrdude -p t2313 -c dasa -i 5000 -P /dev/cu.PL2303-000013FD
avrdude: AVR device not responding
         this check.
Vestibule Chaperone
by Vestibule Chaperone on Tue Aug 12, 2008 4:46 am
OK! So, with further investigation, I've connected the USB-Serial conv. straight into the USB port, vs into the hub as I did earlier.
Interesting observation: the (serial or whatever) changed from /dev/cu.PL2303-000013FD to /dev/cu.PL2303-0000101D. Secondly...iT wOrKs! Huzzah!!!. So perhaps the first chip wasnt 'ruined', but I might have been running in thru a hub and therefore the microcontroller wasnt receiving enough power.
Thanks for answering my question!
Vestibule Chaperone
Re: Programmed once, but wont let me do it again.
by dosh_ance on Mon Jul 26, 2010 6:27 pm
how do i do this in windows? i thought it would be better if i were to expand my knowledge.
i did use the pl2303 in the arduino ide but not avrdue.
any idea how to do this in windows?
dosh_ance
