So far, I have followed the steps here (http://ladyada.net/make/minipov3/software.html#macosx) to the letter, starting by installing Xcode, then installing OSX-AVR. I also installed the mac driver for my usb-to-serial converter, which is an airlink 101 using the same chipset as the PL-2303. There is a mac driver available here (http://www.prolific.com.tw/eng/downloads.asp?ID=31) which I installed with no problems. In fact, it reads data from the SIM card reader available from LadyAda perfectly. However, whenever I try to program a minipov, using this:
avrdude -p t2313 -c dasa -P /dev/cu.usbserial
cma-11-119:~ phildini$ avrdude -p t2313 -c dasa -P /dev/cu.usbserial
avrdude: AVR device not responding
this check.
avrdude done. Thank you.
avrdude -p t2313 -c dasa -i 2000 -P /dev/cu.usbserial
I have tried two minipovs, one on its own and one with the brain machine kit. Neither have successfully been programmed. Any help appreciated.
