MiniPOV firmware with a font, longer text
by sparr on Fri Dec 05, 2008 2:49 am
I am not sure what use case there might be for 1200 characters of text in a MiniPOV, but if you think of one (or just want really easy text editing) then here is some source for you! It uses a 5x8 font with 64 characters (0-9,A-Z,a-z,space,other). The font and the display text are stored in program memory space.
// original code by LadyAda (and other contributors?)
// modified with font/string support by sparr
// subject to the license of the MiniPOV3 project
#include <avr/io.h>  // this contains all the IO port definitions
#include <avr/interrupt.h>
#include <avr/pgmspace.h>
#define TIMER1_PRESCALE_1 1
// store all the font data in program memory (ROM)
// instead of RAM (the default)
const char font[64*5] PROGMEM; // defined below
// store the text to be displayed in ROM too
const char text_string[] PROGMEM = "0123456789 ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz ## ";
// special pointers for reading from ROM memory
PGM_P text_string_p PROGMEM = text_string;
PGM_P font_p PROGMEM = font;
#define NUM_ELEM(x) (sizeof (x) / sizeof (*(x)))
int imagesize = NUM_ELEM(text_string)*6-6; // -6 gets rid of the trailing null
// this function is called when timer1 compare matches OCR1A
uint16_t j = 0;
SIGNAL( SIG_TIMER1_COMPA ) {
   uint8_t out;
   if (j >= imagesize)
      j = 0;
   // read one column from ROM
   if(j%6<5) {
      out = pgm_read_byte(text_string_p + j/6); // the character we are on
         font_p + (
            (out>='0'&&out<='9')?(out-'0'):
            (out>='A'&&out<='Z')?(out-'A'+10):
            (out>='a'&&out<='z')?(out-'a'+36):
            (out==' ')?(62):(63)
      ) * 5   + j % 6); // one column from the character
   } else {
      out = 0; // blank column between letters
   PORTB = out; // display the loaded column
   j++;
int main(void) {
   DDRB = 0xFF;         // set all 8 pins on port B to outputs
      desired freq = 400Hz
      clock freq = 8MHz
      8MHz / (400Hz * 2) = 10000
   TCCR1B = (1 << WGM12) | TIMER1_PRESCALE_1;
   OCR1A = (uint16_t)10000;
   TIMSK |= 1 << OCIE1A;   // Output Compare Interrupt Enable (timer 1, OCR1A)
   sei();                        // Set Enable Interrupts
   while (1);
// font inspired by many 5x8 fonts from various sources
const char font[64*5] PROGMEM = {
 0b01111110,
 0b10100001,
 0b10011001,
 0b10000101,
 0b01111110, //0
 0b00000000,
 0b10000010,
 0b11111111,
 0b10000000,
 0b00000000, //1
 0b10000010,
 0b11000001,
 0b10100001,
 0b10010001,
 0b10001110, //2
 0b01000010,
 0b10000001,
 0b10001001,
 0b10001001,
 0b01110110, //3
 0b00011000,
 0b00010100,
 0b00010010,
 0b11111111,
 0b00010000, //4
 0b01001111,
 0b10001001,
 0b10001001,
 0b10001001,
 0b01110001, //5
 0b01111110,
 0b10001001,
 0b10001001,
 0b10001001,
 0b01110010, //6
 0b00000001,
 0b11000001,
 0b00110001,
 0b00001101,
 0b00000011, //7
 0b01110110,
 0b10001001,
 0b10001001,
 0b10001001,
 0b01110110, //8
 0b01000110,
 0b10001001,
 0b10001001,
 0b10001001,
 0b01111110, //9
 0b11111110,
 0b00001001,
 0b00001001,
 0b00001001,
 0b11111110, //A
 0b11111111,
 0b10001001,
 0b10001001,
 0b10001001,
 0b01110110, //B
 0b01111110,
 0b10000001,
 0b10000001,
 0b10000001,
 0b01000010, //C
 0b11111111,
 0b10000001,
 0b10000001,
 0b10000001,
 0b01111110, //D
 0b11111111,
 0b10001001,
 0b10001001,
 0b10001001,
 0b10000001, //E
 0b11111111,
 0b00001001,
 0b00001001,
 0b00001001,
 0b00000001, //F
 0b01111110,
 0b10000001,
 0b10000001,
 0b10010001,
 0b11110010, //G
 0b11111111,
 0b00001000,
 0b00001000,
 0b00001000,
 0b11111111, //H
 0b00000000,
 0b10000001,
 0b11111111,
 0b10000001,
 0b00000000, //I
 0b01100000,
 0b10000000,
 0b10000001,
 0b01111111,
 0b00000000, //J
 0b11111111,
 0b00001000,
 0b00010100,
 0b00100010,
 0b11000001, //K
 0b11111111,
 0b10000000,
 0b10000000,
 0b10000000,
 0b10000000, //L
 0b11111111,
 0b00000110,
 0b00111000,
 0b00000110,
 0b11111111, //M
 0b11111111,
 0b00000110,
 0b00011000,
 0b01100000,
 0b11111111, //N
 0b01111110,
 0b10000001,
 0b10000001,
 0b10000001,
 0b01111110, //O
 0b11111111,
 0b00001001,
 0b00001001,
 0b00001001,
 0b00000110, //P
 0b01111110,
 0b10000001,
 0b10100001,
 0b01000001,
 0b10111110, //Q
 0b11111111,
 0b00001001,
 0b00001001,
 0b00011001,
 0b11100110, //R
 0b01000110,
 0b10001001,
 0b10001001,
 0b10001001,
 0b01110010, //S
 0b00000001,
 0b00000001,
 0b11111111,
 0b00000001,
 0b00000001, //T
 0b01111111,
 0b10000000,
 0b10000000,
 0b10000000,
 0b01111111, //U
 0b00011111,
 0b01100000,
 0b10000000,
 0b01100000,
 0b00011111, //V
 0b11111111,
 0b01100000,
 0b00011100,
 0b01100000,
 0b11111111, //W
 0b11000011,
 0b00110100,
 0b00001000,
 0b00110100,
 0b11000011, //X
 0b00000011,
 0b00001100,
 0b11110000,
 0b00001100,
 0b00000011, //Y
 0b11000001,
 0b10100001,
 0b10011001,
 0b10000101,
 0b10000011, //Z
 0b00100000,
 0b01010100,
 0b01010100,
 0b01010100,
 0b01111000, //a
 0b01111111,
 0b01000100,
 0b01000100,
 0b01000100,
 0b00111000, //b
 0b00111000,
 0b01000100,
 0b01000100,
 0b01000100,
 0b00101000, //c
 0b00111000,
 0b01000100,
 0b01000100,
 0b01000100,
 0b01111111, //d
 0b00111000,
 0b01010100,
 0b01010100,
 0b01010100,
 0b01001000, //e
 0b00000100,
 0b01111110,
 0b00000101,
 0b00000001,
 0b00000000, //f
 0b10011000,
 0b10100100,
 0b10100100,
 0b10100100,
 0b01111000, //g
 0b01111111,
 0b00000100,
 0b00000100,
 0b00000100,
 0b01111000, //h
 0b00000000,
 0b00000000,
 0b01111010,
 0b00000000,
 0b00000000, //i
 0b00000000,
 0b01000000,
 0b10000000,
 0b01111010,
 0b00000000, //j
 0b01111111,
 0b00010000,
 0b00101000,
 0b01000100,
 0b00000000, //k
 0b00000000,
 0b00000000,
 0b01111111,
 0b00000000,
 0b00000000, //l
 0b01111000,
 0b00000100,
 0b00001000,
 0b00000100,
 0b01111000, //m
 0b01111100,
 0b00001000,
 0b00000100,
 0b00000100,
 0b01111000, //n
 0b00111000,
 0b01000100,
 0b01000100,
 0b01000100,
 0b00111000, //o
 0b11111100,
 0b00100100,
 0b00100100,
 0b00100100,
 0b00011000, //p
 0b00011000,
 0b00100100,
 0b00100100,
 0b00100100,
 0b11111100, //q
 0b01111100,
 0b00001000,
 0b00000100,
 0b00000100,
 0b00000100, //r
 0b01001000,
 0b01010100,
 0b01010100,
 0b01010100,
 0b00100100, //s
 0b00000000,
 0b00000100,
 0b01111111,
 0b01000100,
 0b00000000, //t
 0b00111100,
 0b01000000,
 0b01000000,
 0b01000000,
 0b00111100, //u
 0b00001100,
 0b00110000,
 0b01000000,
 0b00110000,
 0b00001100, //v
 0b00111100,
 0b01000000,
 0b00110000,
 0b01000000,
 0b00111100, //w
 0b01000100,
 0b00101000,
 0b00010000,
 0b00101000,
 0b01000100, //x
 0b10011100,
 0b10100000,
 0b10100000,
 0b10100000,
 0b01111100, //y
 0b01000100,
 0b01100100,
 0b01010100,
 0b01001100,
 0b01000100, //z
 0b00000000,
 0b00000000,
 0b00000000,
 0b00000000,
 0b00000000, //blank
 0b11111111,
 0b11111111,
 0b11111111,
 0b11111111,
 0b11111111  //unknown
One odd point... using AVR Studio and WinAVR I was able to make the font array two dimensional and simulate the code successfully. Using avr-gcc I get errors when trying to compile that way, so I just made the array 1D which didn't affect the actual code at all.
Apologies to whomever 0b does not work for. I know that ladyada uses the B8() macros, but they seem like bloat to me (and, to be honest, they highlight weirdly in my editor).
sparr
Re: MiniPOV firmware with a font, longer text
by naxxtor on Tue Mar 09, 2010 8:42 pm
Holy topic ressurection!
However, just like to say that this modification is awesome, and we are using it for our custom firmware version for a workshop:
http://tinkersoc.org/wiki/projects:tinkerpov
We made one modification - mainly that instead of reading the string out of PROGMEM it's coming out of EEPROM instead.
Cheers!
naxxtor
