sensor
sensor
by reepooh2004 on Thu Jan 15, 2009 12:15 pm
in schematic, pin 6 connect with + and - (sensor). what is the function of sensor? there isn't component in there..
thanks
reepooh2004
Re: sensor
by sparr on Thu Jan 15, 2009 8:06 pm
The sensor is an optional component, and there are various firmwares that use different types of sensors. If you are going to wave the device back and forth then a mercury or ball tilt sensor can be used. If you are going to spin the device in a circle then you could use a rotary encoder or a hall effect sensor or something else.
sparr
Re: sensor
by anubis7777 on Wed Mar 24, 2010 4:22 pm
hi guys, im doing the "make magasine 3x3x3 led cube" project and using the minopov 3 kit for my open source...
and im just wonering about the sensonr slot in the board. ah how does it work and im planing to put a "LDR" for my cube so that when its dark it will turn on and do its patern lights. so how should i go about this.
thanks in advance for rplying to this post just need some help in the sensor bit.
hope to hear from you guys
anubis7777
Re: sensor
by mtbf0 on Thu Mar 25, 2010 2:48 am
sorry, dude, no analog inputs on this baby, but maybe you can find an ldr that will hit the threshold for a logical zero at just the light intensity you want. maybe you can tune things a little with a voltage divider. alas, i'm pretty worthless on hardware questions.
mtbf0
Re: sensor
by anubis7777 on Thu Mar 25, 2010 7:24 pm
ah cool thanks for the replay man, its ok man, any input is better than nothing. ah ur info kinda help me there abit and gave me an idea but still thanks again with the reply.
ur cool :)
anubis7777
cron
