MiniPOV4_ImageConverter code error
by Otb213 on Wed Apr 13, 2016 1:08 am
Hello recently purchased the MiniPOV4 and have enjoyed putting this kit together. Everything is working as it should and I have received the initial flashing light design that comes standard with the component. I am now trying to modify the display and I am getting code errors when I try and run the MiniPOV4_ImageConverter in the Processing IDE as instructed in the learn section of the kit's webpage. I am not particularly good at coding and really need some help with this issue.
Otb213
Re: MiniPOV4_ImageConverter code error
by hiduino on Wed Apr 13, 2016 4:30 pm
Can you list the errors you are getting?
hiduino
by Otb213 on Sat Apr 16, 2016 2:31 pm
Here is the list of errors produced by the IDE
Line 63) The method setLabel(String) from the type Controller<Button> is deprecated
Line 70) The method setLabel(String) from the type Controller<Button> is deprecated
Line 77) The method setLabel(String) from the type Controller<Button> is deprecated
Line 84) The method setLabel(String) from the type Controller<Button> is deprecated
Line 205) The function "showOpenDialog()" expects parameters like:"showOpenDialog(Component)"
Line 311) The function "showSaveDialog()" expects parameters like:"showSaveDialog(Component)"
Line 335) The function "showOpenDialog()" expects parameters like:"showOpenDialog(Component)"
Line 375) The value of the parameteris not used
Otb213
by hiduino on Sun Apr 17, 2016 4:30 am
Which version of Processing are you using?
Most likely you will need to use one of the older versions, v2.2.1. There are some compatibility issues with the newer version 3.0.2.
hiduino
by Otb213 on Sun Apr 17, 2016 7:26 am
Yes I am currently using the newest version of processing the 3.0.2 Where can I find the older version?
Otb213
by hiduino on Sun Apr 17, 2016 8:07 am
hiduino
by Otb213 on Sun Apr 24, 2016 3:39 pm
Thank you for the assistance with the proper version of the processing program. Now I am having trouble with my device being recognized by my laptop. I am running Windows 10 and I can't find the proper drivers for my controller to be recognized as USBtiny so I can try and upload the test design imagines to my minipov
Otb213
by hiduino on Sun Apr 24, 2016 5:19 pm
You can try these drivers, https://learn.adafruit.com/adafruit-arduino-ide-setup/windows-setup. It should contain the USBtiny drivers.
hiduino
