3.5" PiTFT OctoPrint Rig - Installation Issue
by sriggs on Sat Jun 11, 2016 12:05 pm
I'm having an issue getting the '3.5" PiTFT OctoPrint Rig' working. Either the steps are not straight forward or I'm just lost. This is what I have done thus far.
I installed the 'Jessie-based PiTFT 3.5" Image'. I have a Pi3. Once I load that on the SD card, it boots up fine, and boots into the gui and I get it connected to the wireless (wlan0).
-The part on which I'm confused is the second step(s). It talks about the Raspian image, but I have Jessie. If I load the Raspian image it will delete the Jessie image.
-The other thing I tried was I went to the octopi web page and tried to install "Installing from source", Even though the Jessie image has python 2.7.x already I tried the steps starting with step #2. Step 2.1 works fine when I issue the command; Step 3 is where the command does not work.
( note: I tried via ssh and directly to Pi)
To summarize.
I have the Jessie image and I was trying to add the Octopi program to it. Is this incorrect? Am I totally off base? or Should I use a different image? The steps are not clear to me. Would it be possible to list a step by step instruction or some kind? I'm sure other folks may have figured it out.
Thanks (in advance)
sriggs
Re: 3.5" PiTFT OctoPrint Rig - Installation Issue
by pixil3d on Tue Jun 14, 2016 3:24 pm
Hey there,
Don't worry about the wording, "Raspbian" - OctoPrint will run completely fine on the Jessie-based 3.5" image. Once you're Pi is booted and loaded in the GUI, log onto your WiFi network (or use ethernet). Once you get an IP from the Pi, I recommend using your desktop computer to SSH into the Pi and install the dependencies following the "Basic Setup" wiki guide.
To clarify things, I've put together a step-by-step video walkthrough installing OctoPrint from start to finish. I'm in the progress of exporting / uploading it to the Adafruit Youtube channel - will share link when its up.
Best of luck!
–Noe
pixil3d
by sriggs on Tue Jun 14, 2016 3:27 pm
Thank you very much!
I appreciate you taking the time out to do it.
I'll check it out.
See ya on 3D Thursday.
sriggs
by pixil3d on Tue Jun 14, 2016 4:29 pm
Video walkthrough is uploaded!
https://www.youtube.com/watch?v=thQ3PdLxqe8
pixil3d
by sriggs on Tue Jun 14, 2016 6:29 pm
@Noe and @Pedro. Thanks so much for the Video....Just Awesome!!. I had no problems following along...Flawless.
Thank you so much. I appreciate it very, very much. Thank you for that clarification.
See you on 3D Thursday.
sriggs
by ArtK on Thu Jul 07, 2016 10:18 pm
I'd also like to say thanks for the video. I'm pretty much there but I'm struggling with the Webcam component and your video didn't cover that. I'm following the github instructions and the second line of the first Webcam block reads:
sudo apt-get install subversion libjpeg8-dev imagemagick libav-tools cmake
After confirming that I want to continue I see this block of error messages related to imagemagick:
Do you want to continue? [Y/n] Y
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main imagemagick-common all 8:6.8.9.9-5
404 Not Found [IP: 5.153.225.207 80]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavdevice55 armhf 6:11.6-1~deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libavfilter5 armhf 6:11.6-1~deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libav-tools armhf 6:11.6-1~deb8u1+rpi1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmagickcore-6.q16-2 armhf 8:6.8.9.9-5
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmagickwand-6.q16-2 armhf 8:6.8.9.9-5
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libsvn1 armhf 1.8.10-6+deb8u2
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main imagemagick-6.q16 armhf 8:6.8.9.9-5
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main imagemagick armhf 8:6.8.9.9-5
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libmagickcore-6.q16-2-extra armhf 8:6.8.9.9-5
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main subversion armhf 1.8.10-6+deb8u2
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... -5_all.deb 404 Not Found [IP: 5.153.225.207 80]
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... _armhf.deb 404 Not Found [IP: 5.153.225.207 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I tried installing ImageMagick:
sudo apt-get install imagemagick
But that produced its own chain of error messages:
I'm pretty much stymied here. any idea what I can try next?
Art
ArtK
by cagtag on Sun Aug 14, 2016 3:25 pm
Firstly, I would like to thank you for your videos for Octopi set up.
In the "How to Set Up Raspberry Pi Camera with @OctoPrint3D : https://www.youtube.com/watch?v=3ecVLfa3pas" video, you didn't show how can we start webcam automatically every time?
I don't understand what I do after the line: (https://github.com/foosel/OctoPrint/wik ... ian#webcam)
"If you want to be able to start and stop mjpeg-streamer from within OctoPrint, put the following in /home/pi/scripts/webcam:"....
Please help.
Thanks.
cagtag
by 976976 on Mon Oct 03, 2016 4:24 pm
I'm also stuck at this point. Have webcam working but cannot sort the autostart scripts for it. Would be so good to have another video to follow!!
976976
by rschneider82 on Thu Oct 06, 2016 1:09 pm
Trying to access config.yaml to add the addtional options list on the https://github.com/jonaslorander/OctoPiPanel
Keeping getting Permission denied. Can't find anything on the web on how to accress the config.yaml file.
rschneider82
by ArtK on Thu Oct 06, 2016 1:22 pm
This is the first and only maker project I've ever given up on. After many hours, 2 Raspberry pi boards (A pi 3 just wouldn't work) and 2 webcams, I ended up with a device that worked briefly and then consistently crashed. Bummer.
ArtK
