eeprom...
by diplowave on Fri Aug 23, 2019 3:33 pm
Hi, the eeprom CAT25320LI-G is not available, by which candidate to replace it?
diplowave
Re: eeprom...
by antto on Mon Aug 26, 2019 12:46 pm
any eeprom that is SPI (not i2c, not parallel), 4MHz or faster, 4KBytes (or 32Kbit), in DIP-8 or SMD SO-8/SOIC-8 (but via an adapter board)
FRAM also works, there if you can't find 4KBytes, you can choose a chip with bigger capacity (up to 64KBytes) since the page size doesn't matter
here's what i use in mine: Image
antto
Re: eeprom...
by diplowave on Mon Aug 26, 2019 4:03 pm
Yes, thanks. https://www.mouser.fr/ProductDetail/ON- ... kM7g0oo%3D
I had a Chinese x0x of a guy, i looked, there is another kind of eeprom in smd, but i can not read, maybe A1ML 58BL 0F2250A?:
diplowave
Re: eeprom...
by antto on Tue Aug 27, 2019 1:27 pm
seems i can't edit my post
forgot to mention: it has to work at 5V, and if the eeprom size is different, check that the page size is 32 bytes, since a firmware written (properly) for the original eeprom (as per the BOM) would expect the page size to be 32 bytes
if you're gonna use FRAM - the page size won't matter
the eeprom you linked is 8KBytes, automotive grade, the pinout matches, it's SOIC-8 (you'll need an adapter), it has some extra fancy features, i guess it shouldn't be a problem, the page size is 32
this one should certainly work: https://eu.mouser.com/ProductDetail/Mic ... %252BOw%3D
also 25LC320A-I/P (same as above but different operating voltage range, still runs at 5V)
antto
Re: eeprom...
by sterlinghatton on Thu Sep 26, 2019 3:25 am
http://forum.distributique.com/profile.php?id=30711 stanleyboston
I have Soic8 Pogo Pin Adapter for EEPROM / 93cxx / 25cxx / 24cxx and I think it will suit your purposes. It fits fit universal EEPROM programmer with ZIF Socket. A DIP adapter board is included.
sterlinghatton
