🎄⛄❄️🎁 It's beginning to look a lot like ADABOX-mas! The next ADABOX from Adafruit ships soon! Get yours now, or give as a gift! 🎄⛄❄️🎁
alternative parts
Re: alternative parts
by textile on Wed Aug 11, 2010 11:16 pm
LM358 is excellent replacement for AN6562 . No noticeable differences. Power sits on 5.333v. VCO behaves normal.
textile
by phono on Sat Sep 04, 2010 3:16 am
textile wrote:LM358 is excellent replacement for AN6562 . No noticeable differences. Power sits on 5.333v. VCO behaves normal.
There will be a difference, the lm will be cleaner, but yes I've also tested lm358 and found no noticeable difference
x0x #733 Image SH-101 MC-202 TB-303 TR-606 TR-808 TR-909 MKS-50 Juno-106 A-100 Virus-B E-6400 SX-150 Monotron
phono
by altitude on Sat Sep 11, 2010 3:36 pm
Dont know if this has been brought up but the J201 is an great replacement for the 2sk30A-O (VCO). The pinout is different D S G vs D G S, but I have one in mine right now and I cant tell a difference..
altitude
by exactspace on Thu Sep 16, 2010 12:25 am
Can the M74HC166B1R replace the 74HC165?
Alternatively, are they in any way compatible to M74HC59B1?
exactspace
by altitude on Thu Sep 16, 2010 7:35 am
exactspace wrote:Can the M74HC166B1R replace the 74HC165?
No and no.
165 and 166 are both PISO shift registers but have a completely different pinouts. I have no idea what the third part is. Compatible parts will usually be the same type of logic chip made by different manufactures so SN74HC165N, M74HC165B1R, etc are the all interchangable (74HC165 being the key thing). There are of course exceptions but that is a general guideline to follow
altitude
by exactspace on Thu Sep 16, 2010 12:38 pm
Thanks Altitude. For some reason I got those ICs and not 74HC165's.
exactspace
by altitude on Thu Sep 16, 2010 12:41 pm
exactspace wrote:Thanks Altitude. For some reason I got those ICs and not 74HC165's.
I saw the other thread. Did you get them from willzyx or TT?
altitude
by exactspace on Thu Sep 16, 2010 1:20 pm
It's before willzyx had the complete kits, so I got them from Mouser because they said they would be compatible. :lol: They didn't have the 74HC165's in stock. Also, I have no idea why I have the extra ICs.
Oh well. Time to desolder these ICs!
exactspace
by exactspace on Tue Sep 21, 2010 2:42 pm
It worked. Thanks Altitude!
exactspace
by textile on Sat Oct 09, 2010 9:53 pm
textile
by Brassteacher on Wed Dec 01, 2010 1:42 pm
textile wrote:http://au.mouser.com/Search/ProductDetail.aspx?R=LT1/4LT52R102J3900virtualkey66000000virtualkey660-LT1/4LT52R102J39
These thermistors work very well.
@textile, I've been meaning to thank you for finding these. I have them installed in a couple projects now, and I'm very pleased with them. Also, at 3 for $1, you can't beat the price!
Also, everyone, I can confirm that 2SC2259 is a viable alternative to 2SC1583. I've tested one in the VCO of my experimental x0x build, and the traces off the VCO on my oscilloscope were indistinguishable. I have yet to test in the filter, where it may actually change things a bit, as the C2259 basically IS a C1583, but with a much wider and higher range of Hfe values.
Don Taylor, a.k.a. Brassteacher
"Jack of all trades, master of none, proficient at even fewer..."
Brassteacher
by altitude on Mon Dec 06, 2010 7:13 pm
BC639 and BC640 work very well in the current mirror of the BA6110 based VCA. Samples in the thread..
altitude
by isak on Sun Apr 15, 2012 7:59 am
Hi guys.
As I understand I could replace the 2sk1583 with 2 mached transistors?
If yes.. which ones?
Cheers,
Isak E.
isak
by Gaetano on Sun Apr 15, 2012 6:42 pm
isak wrote:Hi guys.
Cheers,
Isak E.
2SC1583 = dual NPN, 2sk1583 = Mosfet i.e., the wrong type.
To make your own x0xb0x the 'Rare' parts are here: viewtopic.php?f=29&t=5526
(BA6110, AN6562, 2SC2291, 2SC1583, 2SK30AO, 2SK30AY, LA4140, 2SC945P or 2SC536F, 2SA733AP)
All the other parts are easy to get.
Gaetano :)
Gaetano
by isak on Mon Apr 16, 2012 7:17 am
Sorry, I meant 2sc1538.
Iv read that the dude from the ML303 found that 2 X 945 can replace 2sc1583, and the results are very good.
http://ultra303.ultrafex.de/diary.phtml
isak
