DC bias problem
xtals
DC bias problem
Post by xtals »
Hi! :)
I've started to build my xox (from Zwillyx shop).
Following the manual at page 37 i'm supposed to test DC bias and have 8.5VDC, but when i put the multimeter probes i read a 0v value.
All other voltages are fine according the manual.
What you suggest to check?
antto
Re: DC bias problem
Post by antto »
you've probably received some printed build manual, but in the past most folks have used the online build manual, which is not paged like a book
so can you clarify exactly at what point of the build process you are that instructs you to measure that voltage?
xtals
Re: DC bias problem
Post by xtals »
Hi!
I'm using this manual:
http://www.ladyada.net/make/x0xb0x/fab/vco.html
I think that's the same from the Willzyx site after all!
antto
Re: DC bias problem
Post by antto »
most probably it's the same manual, printed on paper
but my question was: what is on page 37?
xtals
Re: DC bias problem
Post by xtals »
This:
And that's the description:
"If you don't have a scope, you should at least measure the DC bias, which is about 8.5VDC"
Then, measuring with multimeter at the resistor i have 0V!
thanks
xtals
Re: DC bias problem
Post by xtals »
Update:
I have solved the problem: Q26 (2SC1583) had some really bad soldering on it...on the smd part a lot of solder paste was left unsoldered and then some pins was shorted.
Cleaned it with ultrasonic bath first and then resoldered, DC bias is perfect now!
Thanks again!
Return to “Making x0x”
