DC bias problem
DC bias problem
by xtals on Tue Aug 08, 2017 1:54 pm
Hi! :)
I've started to build my xox (from Zwillyx shop).
Following the manual at page 37 i'm supposed to test DC bias and have 8.5VDC, but when i put the multimeter probes i read a 0v value.
All other voltages are fine according the manual.
What you suggest to check?
xtals
Re: DC bias problem
by antto on Tue Aug 08, 2017 5:26 pm
you've probably received some printed build manual, but in the past most folks have used the online build manual, which is not paged like a book
so can you clarify exactly at what point of the build process you are that instructs you to measure that voltage?
antto
Re: DC bias problem
by xtals on Tue Aug 08, 2017 5:37 pm
Hi!
I'm using this manual:
http://www.ladyada.net/make/x0xb0x/fab/vco.html
I think that's the same from the Willzyx site after all!
xtals
Re: DC bias problem
by antto on Tue Aug 08, 2017 5:42 pm
most probably it's the same manual, printed on paper
but my question was: what is on page 37?
antto
Re: DC bias problem
by xtals on Tue Aug 08, 2017 5:59 pm
This:
And that's the description:
"If you don't have a scope, you should at least measure the DC bias, which is about 8.5VDC"
Then, measuring with multimeter at the resistor i have 0V!
thanks
xtals
Re: DC bias problem
by xtals on Wed Aug 09, 2017 3:21 pm
Update:
I have solved the problem: Q26 (2SC1583) had some really bad soldering on it...on the smd part a lot of solder paste was left unsoldered and then some pins was shorted.
Cleaned it with ultrasonic bath first and then resoldered, DC bias is perfect now!
Thanks again!
xtals
