Filter warble? Check your power input.
by phono on Wed May 28, 2008 9:17 am
reflowed r95, c28 then additionally c30 c29 c22 c16
problem still persists :S, perhaps c28 is bad? r95 is fine, measured 100 ohms
x0x #733 Image SH-101 MC-202 TB-303 TR-606 TR-808 TR-909 MKS-50 Juno-106 A-100 Virus-B E-6400 SX-150 Monotron
phono
Re: Filter warble? Check your power input.
by phono on Sun Dec 21, 2008 5:31 pm
well time to bring this old one up since i never solved this on one of my xox.
I've tried all the mentioned things throughout the forum and it seems the warble isnt related to those issues. I did just make a discovery and that is that if i max all the knobs except decay the warble never starts, but as soon as i dial in 50% on the decay (all other knobs still maxed) the warble starts almost instantly and stops almost as fast when i bring the decay back to 0%.
perhaps the warble is related to the decay circuit in some way, can any of you suggest what i could check in this area to eliminate this dreaded warble once and for all.
phono
by guest on Sun Dec 21, 2008 6:14 pm
do you have an oscilliscope
it might be worth looking at the 12v and 5.333v rails
when the warble is happening
and see if they are moving around any
that would at least eliminate the powersupply as the issue
otherwise one of the cvs to the vcf is acting up
does the envelope work fine elsewise
does it sweep the filter
and change decay times
guest
by phono on Sun Dec 21, 2008 7:34 pm
guest wrote:do you have an oscilliscope
i dont have a real scope unfortunately, everything else works as expected, the envelope seems fine also. The last time i tried finding the fault i remember reading c28 with a volt meter and it was constant with or without warble. It definately seems in some way related to the decay knob though, (with all other knobs maxed) since i can now dial up warble at will, still i've no idea if that gives you any idea as to what i should look for to fix this.
phono
by guest on Sun Dec 21, 2008 8:35 pm
its going to be difficult to find the problem
without a scope
as the issue is a time varying one
so the dc values may not be changing
and just have some ac signal coupled to them
its worth a try to measure the 5.333v and 12v with a voltmeter
even if they dip by 10mv when there is warble
that might indicate something
you could also measure other critical areas with and without warble
c29
c22
c16
c30
the drop across r69
but im not sure it will show anything
guest
by phono on Mon Dec 22, 2008 6:59 pm
guest wrote:its going to be difficult to find the problem
without a scope
c29
c22
c16
c30
the drop across r69
thanks i'll give that a go soon as i get a decent amount of free time to get inside without interuption and i'll post up my results, my meter is kind of cheap so it might read a bit slow, but still its worth a shot since this is really something i'd like to eliminate once and for all
phono
