Power Supply Issue J4 2v instead of 12v
by snufkin on Sun Aug 11, 2019 8:13 am
Hi people,
I pulled out my unbuilt original xox kit to finish it this summer.
I had an issue with the PSU which meant I never built it up.
- The PSU section is however populated.
- I am pretty sure I have the resistors right and soldered in they test OK on the meter (obviously a fallible test).
- Cap orientation looks good.
- I am using an 500ma 9v AC/aAC adaptor that reads 11.17v.
- I already replaced the LM336Z as I have some in my parts bin
- I have done a visual check for shorts/solder debris etc
- TM6 is marked 202 and measures ok resistance (as soldered in place)
Now for the symptoms
- I am getting 2.50v instead of 12v on pin 1 of j4
- I am also getting 5.58 on pin 3 of j4 tm6
Any advice greatly appreciated !
snufkin
Re: Power Supply Issue J4 2v instead of 12v
by snufkin on Sun Aug 11, 2019 1:00 pm
getting 0.47 over d44 through d47
snufkin
by slviaperez on Wed Jan 15, 2020 5:26 am
snufkin wrote:getting 0.47 over d44 through d47 valentines day gifts for her
Thanks very much. It was very helpful.
slviaperez
