Reference voltage lower that expected
Razvysme
Post by Razvysme »
I bought a partial kit from a guy on a FB group, and started building it yesterday, following the build manual and reading the wiki.
I didn't get far because the reference voltage range is between 4.1 and 4.8V, nowhere near the 5.333. I triple checked the resistors, unsoldering one leg and measuring them, and they all comply with the specs. The diodes are all 4148, and the shunt is LM336Z-5.0. Any idea what might be wrong? Below you can see how far i got. Cheerios.
Razvysme
Re: Reference voltage lower that expected
Post by Razvysme »
I got some voltages reading:
d44 d45 juncture - 0.54
d45 r5 juncture - 1.08
r5 tm6 juncture - 1.72
tm6 r4 juncture - 2.22
r4 d46 juncture - 3.62
d46 d47 juncture - 4.16
d47 r3 juncture - 4.70
r3 r2 juncture - 7.50 (26.0)
r2 r1 juncture - 7.91 (29.0)
lm7805 pin 3 - 4.98
78l06 pin 1 - 5.98
MKRVR
Post by MKRVR »
Did you ever get any help with this?
I just started building a X0xbox kit from Willzyx (recieved it as a gift)
I have the same issue with reference voltage, no where near the required 5.333V. I only get 4.26 to 4.28V !
Seems like most of the responses and help are 5 to 10 years old. Is this forum still active?
Razvysme
Post by Razvysme »
Yes i did. I ended up changing the resistors R4 and R5. Acoording to the power supply datasheet, the sum of the resistors needs to be less than 21k(if i remember well), so i just trialed different resistors until i got a good value. R4 is 6.4k and R5 is 1k. To make my life easier, i installed some single pin sockets so i could just swap resistors easily.
Resistors
Resistors
Return to “Making x0x”
