Midi Sync and restarting at the start note!
Moderators: altitude, adafruit_support_bill, adafruit, hamburgers, phono
by safetyboy on Fri Mar 04, 2011 10:40 am
Not sure how to explain this,
Running x0x with Maschine, midi out to midi in x0x, works fine until i hit the back button on the maschine to restart the pattern but the x0x keeps playing and wont return to the start of the pattern. So it all goes out of sync.
Any Ideas?
safetyboy
Re: Midi Sync and restarting at the start note!
by xlarge on Fri Mar 04, 2011 10:50 am
Press stop first, then rewind and then start?
xlarge
by safetyboy on Fri Mar 04, 2011 11:04 am
Still does the same thing x0x sticks to the last note it was on!
safetyboy
by xlarge on Fri Mar 04, 2011 1:47 pm
I wonder how maschine works with midisync... Seems to do it wrong anyhow ;)
xlarge
by safetyboy on Fri Mar 04, 2011 2:14 pm
Getting a strange buzz when i plug into midi thru and mid out when maschine is midi'd to x0x!
There is no Buzz when i unplug from the maschine end!
safetyboy
by xlarge on Fri Mar 04, 2011 3:50 pm
There might be a setting in maschine somewhere regarding midi sync.. reset on pause/stop?
That might rob you of pausing and then continuing... i have no idea how maschine works, sorry.
xlarge
by safetyboy on Fri Mar 04, 2011 4:03 pm
It triggers the x0x grand and stops it, just doesn't reset it back to the start of the pattern!!
I thought this would be easy :(
safetyboy
by guest on Fri Mar 04, 2011 6:44 pm
i dont think the stock firmware
restarts at the beginning a sequence
guest
by safetyboy on Sat Mar 05, 2011 1:56 am
Sokkos doesnt seem to either!
safetyboy
by xlarge on Fri Mar 11, 2011 3:10 pm
Well it does here...And i think I've said it before.
Is your midi source really sending the start and not continue message?
xlarge
by safetyboy on Fri Mar 11, 2011 4:15 pm
I'm using Maschine 1.6
midi out / send midi clock
not much else i can change in the preferences.
safetyboy
by xlarge on Sat Mar 12, 2011 7:09 am
Try something else.
You're not alone with maschine sync issues (although that's perhaps two years ago...):
https://www.native-instruments.com/foru ... p?t=131971
xlarge
