x0xb0x BOM v1.9 attached (last updated March 6 2009)
Re: x0xb0x BOM v1.9 attached (last updated March 6 2009)
by Luap on Wed Dec 08, 2010 11:44 am
XceR wrote:BA662A was made by Roland, thus it's impossible to get unless you salvage a Roland synth. Sometimes they pop up on eBay.
I managed to get a brand spanking new one from Vintage Planet. They often have them. But at the time of writing, they have none.
It is NOT a key component to the 303 sound though. So considering that it is usually an expensive part, it is not worth seeking out. The 6110 is plenty good enough.
Luap
Re: Polyester Caps
by LoopStar on Fri Dec 09, 2011 7:30 pm
synthasonic wrote:Hmmm... I bought a WillZYX express kit, thinking I'd be all set b/c I have a lot of parts sitting around, only to discover that Mouser and Digikey no longer carry polyester caps. Jameco's site is currently down, so I can't check there. Small Bear has a few, but not all of the values needed for a x0xb0x. Can anyone recommend another source for these caps?
Sam E.
Ran into the same problem recently when sourcing the parts for my thitrd x0x (had some parts lying around). I replaced the Xiconn caps with Wima caps. Took me some time to find out which cap had the right spacing. Also the Wima caps are quite big, so thing got quite narrow in some places. b0x works like a charm nontheless!
website: http://www.myownmusic.de/artistpage_info.php?artist_id=141458
LoopStar
Re: Polyester Caps
by LoopStar on Fri Dec 09, 2011 7:32 pm
Sam E.
Ran into the same problem recently when sourcing the parts for my thitrd x0x (had some parts lying around). I replaced the Xiconn caps with Wima caps. Took me some time to find out which cap had the right spacing. Also the Wima caps are quite big, so thing got quite narrow in some places. b0x works like a charm nontheless! Only cap I didn't get from Wima was the .018uF (2A183K). Fortunately http://www.musikding.de still carried the Xicon one.
LoopStar
by decoder23 on Sat Dec 10, 2011 7:04 am
check out the yx series form nichicon. all required values are available at digikey.
decoder23
by stinkleton on Tue Jul 09, 2019 3:36 pm
The entry for the 4066 IC should be updated in the BOM.
It is not enough to get a 4066 that "has "4066" somewhere on the body".
It must have an operating voltage that can handle 12v.
ex.
CD4066BE will work.
74HC4066 will not.
stinkleton
