📣📪 🚚 Adafruit will not be shipping USPS orders Monday January 20, 2020 🗓. Expedited USPS orders placed after 11am ET 🕚 Friday January 17 will go out Tuesday January 21 📣📪🚚
How does the I/O fit in?
by Pish on Mon Apr 15, 2013 6:43 pm
I'm building the VCO.
Built a little kit from maplin as the power supply.
http://www.vellemanusa.com/products/vie ... &id=350481
Put a battery on it. Connected up.
Power supply on.
TM4/5 Centred.
Checked the DC bias using my meter. CORRECT.
It performs like it should like it says in the instructions, I can hear buzzing that changes pitch
But using the sound card scope and the suggested soldered clips it doesnt look very saw like.
Anything I should check or carry on?
Pish
Re: Testing VCO with soundcard scope. Doesnt look the same.
by antto on Mon Apr 15, 2013 7:02 pm
i'd say ignore this, either the scope or soundcard is acting weird
the VCO is biased so it might be clipping in your soundcard inputs
you could try running the probe signal thru a 1Meg pot and adjust it while looking at the scope
antto
by Pish on Mon Apr 15, 2013 7:05 pm
Using 7805 tab for both power and scope grounds
Pish
by Pish on Mon Apr 15, 2013 7:07 pm
Instead of the 10k pot on the probes?
Pish
by MMM on Tue Apr 16, 2013 3:19 am
The scope pics don't even look remotely like the real waveform.
First of all the waveform looks like it has both positive and negative symmetrical components; this shouldn't happen with the sawtooth at all.
In addition it appears as if it has just about 200mV peak to peak; this would be way too small.
I don't know if this is the result of the soundcard scope acting up.
MMM
by Pish on Tue Apr 16, 2013 2:43 pm
Any suggestions then?
Pish
by antto on Tue Apr 16, 2013 3:49 pm
if it sounds fine - my suggestion is to continue forward with the build
you can check the signal again once you put the VCF together
antto
by Pish on Tue Apr 16, 2013 5:31 pm
Is there anything I can test my soundcard scope against?
Pish
by Pish on Tue Apr 16, 2013 7:09 pm
Is it worth making a little frequency generator kit to test it on?
Pish
by antto on Wed Apr 17, 2013 2:28 pm
well, it's up to you
but IMO you can simply continue and checks things again when you build the VCF section
antto
by Pish on Wed Apr 17, 2013 5:48 pm
Cheers mate.
Ill just make sure I keep logs as i go
Pish
by Pish on Mon Apr 22, 2013 6:41 pm
Got a second hand, hand held Velleman HPS140. I'll give it a go tomorrow.
Pish
by Pish on Tue Apr 23, 2013 8:32 am
Alot more like it!
Pish
by MMM on Wed Apr 24, 2013 1:45 am
Definitely!
Let us know how everything else turns out.
MMM
by Pish on Wed Apr 24, 2013 1:17 pm
I was worrying I'd done something wrong but, Ive got the solder bug at the moment so I thought £40 for a £100 scope aint too bad.
Built the VCF but broke the point off the probe D: !!!! Have to find/order one
Pish
