how change the port up to 9 in the control software?
Hi all ,just finish a xoxbox,work fine,before i will install a full kit of BCBOX...i am triyng to upload the Sokkos,but in my Device manager,my xoxbox is recogized as COM 9,unluckly i only found ,in the control software port 1 to port 4 what can i do? best regards
Re: how change the port up to 9 in the control software?
Try using different USB ports on your computer.
hi,i 've tried all (6 )my com port change but never less than 8!!!thanks
hi,in proprity of my port com i 've changed for port 1...and the xoxbox reconized in panel device (port)but now the control software didn't find my xoxbox and ask me "are you in the bootload mode? i am in and i ve follow the procedure...???is there a control software update i ve got the version 1.0 best regards
First of all make sure your knob pointer really is pointing at bootload mode, mine was reversed on one of the x0x's i built. Also I've noticed I can only get the firmware upload to work after a fresh reboot and then going directly into control software, with x0x connected and ready to go, wait a few seconds and then do the upload, it can take a few tries to be honest, but I'm using Windows 7 so its probably be picky.
thanks Q. very much; i will try tomorrow(when you write "reboot" i think you talk about the computer?) best regards
I can never connect to the x0xb0x, but i can upload the firmware anyway... maybe just try to upload it, despite you can't connect to the box?
have you updated with the sokkos?thanks
If you are asking me. Then yes, i run SokkOS on both my box'es, and i can connect to none of them, but still upload the firmware
Hi B.what did you done ,have you an error message?explain me ,please;Regards
Set the virtual usb->serial port to 1,2,3 or 4. Start c0ntr0l and select the port you use. Go to the x0xb0x>Upload Firmare, and select the fil. Thats how it works for me. And as i say, i can NEVER connect to the x0xb0x. But the firmware uploads just fine.
SOLVED i was in computer mode......thanks all
Good times! Im sure you will like the SokkOS
- lorne in canada
It is not my skillset but if any codeheads out there could contribute and rewrite control software into something that works, that would be a great service to us all.
I'd do a paypal donation for it and I bet so would any others who could afford it. But again this is a community effort so I am not asking for a commercial product. But it sure would get your name ouut there.
