Bass Boost disappointing???
by JRock on Sun Feb 14, 2010 1:53 pm
Bass boost mod seems disappointing. I put a switch on it. I had to put the wires to the board on 2+5 to make it work. There seems to be a little difference but I was kind of expecting something dramatic. Maybe I didn't do it right? My x0x still sounds great, but I was expecting more of an impact after I put this mod in. My first mod... So if anybody has the same result, or an idea of how I did it wrong I would love to hear from you.
JRock
Re: Bass Boost disappointing???
by JRock on Mon Feb 15, 2010 11:46 am
Does it matter which side of the caps I install the switch on? Right now I have them it in between the caps C20/C21and the resistors R121/R122... anybody know before I solder the new switch on? (The first one had a little plastic screw post and as careful as I was I still managed to strip it out..JUNK!)
JRock
by hamburgers on Mon Feb 15, 2010 4:19 pm
it's not a very exciting mod
hamburgers
by JRock on Mon Feb 15, 2010 10:06 pm
Wonder if there's some different value to really Kick it up?
Thanks for the reply.
JRock
by JRock on Thu Feb 18, 2010 12:50 pm
Sounds pretty sweet now with some old metal distortion in the loop!!
JRock
by JRock on Sun Mar 07, 2010 3:03 am
A lot more noticeable with the VCO frequency modulation
JRock
by alex_dubinsky on Wed Mar 24, 2010 7:05 pm
The problem is in the BA6110. Changing the capacitors changes the ba6110 input a lot, but the output isn't so different. I wonder if BA662 (or different batches of BA6110) would be less of a bottleneck.
alex_dubinsky
by legionhwp on Sun May 09, 2010 1:33 pm
Hmmm, I did the "stock" bass boost mod from the subatomic and ladyada guide and I think it's fantastic.The only setting where it doesn't make things sound "better" to my ears is when i also switch on the distortion mod I did. I have a switch to go from stock to bass boost but overall highly recommend this as one of the easiest and more useful mods.
YMMV I guess
D_
legionhwp
by tempomaster on Fri May 20, 2016 2:12 pm
I just did this mod, and honestly, I can't tell the difference. I didn't do extensive testing, but on the one pattern that I recorded and did a frequency analysis on, the low-end is pretty near identical on both. There was a boost at 5k, but that's not a bass frequency.
tempomaster
by tempomaster on Thu Jun 23, 2016 11:03 am
I'm not sure what all I did, but now I can definitely hear the bass boost.
::shrugs::
tempomaster
by Luap on Thu Jun 23, 2016 12:56 pm
I've done this mod on 2 different x0xb0xes. Although I used the same value caps on both, the brands and voltage rating (and physical size) of the caps were quite different. One x0x definitely has more bass boost than the other..
That said, its still a subtle mod. But play the x0x out over a BIG sound system, and im sure you wont fail to notice it then ;)
Luap
