n0nx0x2 - Stop issues
by gelabs on Sun Jan 26, 2020 3:10 pm
Since the main topic is locked (!?) :
n0nx0x2 (2.11) seems to have issues when stopping the sequencer, be it standalone or midi-slaved. Sometimes it stops correctly, ie: editing is possible in write mode and dinsync stops correctly; but most of the time a note get stuck, editing is not possible and dinsync outputs random pulses and finally restarts. I need to restart/stop the clock several times to stop the sequencer correctly. Is there a setting to correct this ? I tried a reset but it didn't solve this problem.
gelabs
Re: n0nx0x2 - Stop issues
by gelabs on Tue Jan 28, 2020 1:23 pm
If it can be of any help to diagnose the issue : when the problem appears the tempo LED stays lit.
gelabs
by antto on Wed Jan 29, 2020 2:58 pm
gelabs wrote:Since the main topic is locked (!?)
wot?! o_O
a ton of threads are actually locked, in all of the x0xb0x subforums
based on the symptoms, i guess you mean stopping the master causes n0nx0x2 to freeze (tempo LED stops blinking)
this would happen on what i call "lousy" masters which stop generating sync clock when stopped
antto
by gelabs on Thu Jan 30, 2020 8:09 am
I think Zaquencer has a quite healthy implementation of midi clock and still generates the clock even when stopped. I'll have to check that this evening.
Could it be possible to alter the code in the firmware to react to a midistop message (even if the clock stops), and have it reset on step 1 of a pattern just like the other firmwares, for example ?
gelabs
by gelabs on Thu Jan 30, 2020 1:18 pm
So, it appears that Zaquencer does indeed stop generating midiclock when stopped ...
I modified my midi routing and put an x0xb0x as masterclock, less convenient but it works ...
gelabs
by gelabs on Sat Feb 01, 2020 4:01 am
Speaking of n0nx0x, antto, could you please publish the code on Github/Gitlab ?
gelabs
by antto on Sat Feb 01, 2020 9:32 am
it's on gitlab but not public.. for reasons
sync masters which stop the clock when not playing are dumb, they should at least send out one or a few additional clock ticks
or "All Notes Off" or something
antto
by gelabs on Sat Feb 01, 2020 2:44 pm
Oh ok, whatever are those reasons I respect your choice.
I have posted a request on Zaquencer forum about the clock issue, we'll see ...
Thanks anyway.
gelabs
