SokkOS 2.0, beta
Re: SokkOS 2.0, beta
by antto on Fri Aug 23, 2013 5:17 am
to figure out whether it misses a clock tick, or it's just a latency, you can perform this very simple test:
put some repeated CHH or similar sound in your DAW
- start recording, let it run at a fast-ish tempo like 140 or whatever
- reduce the tempo down dramatically, like 30-ish
- stop recording
now load the thing into a sound recorder, measure the delay when the tempo was fast, measure when it was slow, compare
if the delay doesn't change - it's just latency
if it changes, then there is latency PLUS missing clock ticks
antto
by roxxx303 on Fri Aug 23, 2013 8:32 am
antto wrote:to figure out whether it misses a clock tick, or it's just a latency, you can perform this very simple test:
- stop recording
a good idea!
roxxx303
by Pygmy on Mon Sep 23, 2013 4:08 am
Are the files linked to on page 1 of this topic still the latest available version ?
Pygmy
by roxxx303 on Mon Sep 23, 2013 4:32 am
Pygmy wrote:Are the files linked to on page 1 of this topic still the latest available version ?
The newest is the non-beta-2.0-version posted here:
http://forums.adafruit.com/viewtopic.php?f=13&t=43270
roxxx303
by Braincloud on Tue Jun 20, 2017 10:24 am
Amazing! I just bought my x0xb0x and was disappointed that there weren't a lot of patterns pre-loaded. Until I get the hang of programming, it would be nice to have some to play around with. Hoping there might be a user area for uploading and downloading user patterns with the new OS. Thanks!
Braincloud
by Nordcore on Wed Jun 21, 2017 4:14 am
You might try MarOs15, which has some functions to generate new patterns.
Latest version: viewtopic.php?f=13&t=33914&start=315#p593735
I'm still working on the manual, until than you might use what Mario has written ( ... see here: viewtopic.php?f=13&t=33914 ).
MarOs15 works similar to Sokkos. It has (nearly?) all features of Sokkos 2 included. Except for the Track mode, which is missing completely.
FAQ #1 Answer: Storing a pattern works different than in Sokkos: hold "DONE" key down, than press the 1...8 (white) key where your pattern should be stored.
Nordcore
