2 Res pots?
Discuss mods, hacks, tweaks, etc.
andrewF
2 Res pots?
Post by andrewF »
Has anybody separated the dual Resonance pot and wired it up as two separate pots?
worth it? stupid idea?
antto
Re: 2 Res pots?
Post by antto »
i wouldn't do that
the Res pot is dual because it does two things:
1) controls the feedback in the filter (resonance control)
2) smoothens up the Accent signal which modulates the cutoff on accented notes
you can acheive a similar effect if you use the resonance mod (replace R97 with a 10K pot)
when the resonance knob is at maximum - the Accent signal is smoothened, while at low resonance - it's "sharper"
so, boost the R97 pot, and reduce the resonance knob and you get normal resonance but with fast accented cutoff modulation (which isn't so spectacular)
that's if i'm not forgetting something :wink:
andrewF
Re: 2 Res pots?
Post by andrewF »
Thanks for your advice
I will try it anyway, just out of curiousity, its easy to revert. Wondered if it had been done before.
juke179r
Re: 2 Res pots?
Post by juke179r »
Andrew
Did you do the mod?
Return to “x0xm0dz”
