MarOS1.5.0 - Beta Version
Re: MarOS1.5.0 - Beta Version
by Nordcore on Sat Mar 10, 2018 7:09 pm
... that is not as intended... sorry, but that was wrong in my posting above ...
... the #define should be commented out
// #define FLASHCRCCHECK 2
... than the code compiles w/o changes ... and than it has no CRC Check.
All of the option #define work that way: comment them out, than the feature goes away.
If they are defined, their value might control the option in more detail.
Nordcore
by ioth on Tue Mar 13, 2018 8:11 am
Hey Nordcore!
OS is running great so far, just found 2 more small bugs:
Sonetimes when clearing the pattern with the 2x undo, it sets the pattern length to a random step and doesn't clear the steps behind it.
Also slides and accents aren't cleared.
The second bug is about the pattern nudge with the left/right keys, it works but sometimes deletes slides/accents from the patterns.
I will try to isolate the bugs and tell you more about it, but i just noticed these while jamming.
Also one more thing, a friend told me it would be pretty cool if you could choose different playing styles (reverse, alternate, random, etc) you could maybe implement them in the pattern play random mode (tempo enc press) if I remember correctly there are still a few keys left.
I know you're running low on free bytes for the code, just wanted to give you the input.
Best, ioth
ioth
by Louis_Serieusement on Thu Sep 13, 2018 4:38 am
Hi !
Just wanted to say, MarOS15-V1.81 changed my life, thank you so much for this Mario and Nordcore !!!
<3<3<3
Louis_Serieusement
