Re: MarOS1.5.0 - Beta Version
by oyztein on Fri Feb 15, 2019 8:02 am
Hey,
I think I have found a weird bug. I am using MarOS15-V1.81 with the x0xb0x receiving midi in from Logic Pro X 10.4.4, and a TR-606 synced via DIN SYNC OUT from the x0xb0x.
When changing tempos in Logic, the x0xb0x always stay in sync, but the 606 is sometimes playing at the wrong speed. If I for instance go from 120 BPM to 160 BPM (stop/start in between change) the 606 always play at wrong speed (kind of uneven around 155 BPM).
If I increase the speed with 5 each time, from 120, 125, 130, etc. to 160, with stop/start between each change, it ends up synced perfectly at every tempo, including 160.
If I change from 80 to 160, the 606 stays in 80 BPM in sync with the x0x playing 160.
Any idea what´s causing this? I can kind of work around it by decreasing and increasing the tempo in small steps, but it´s pretty annoying, so if it could be fixed that would be great. The behavior is the same with the Disable SYNC fix (Settings #D 2) on or off.
