Accent and Slide CV out?
by Pish on Tue Apr 02, 2013 8:27 pm
Is it possible to do these? I have modded my MC202 with Pitch/Gate/Accent/Port CV ins.
I'm trying to see if I can add these to my x0xbox and possibly even build another x0xb0x but just as a sequencer for the MC202.
Cheers
Pish
Re: Accent and Slide CV out?
by Paradigm X on Fri Sep 01, 2017 2:03 pm
bump
id like this too
particularly a gate which goes high when slide is active. same for accent but beleive this is done from collector of q35?
manyt hanks
Paradigm X
by Nordcore on Sat Sep 02, 2017 3:30 am
Collector of Q29 has the slide signal, switching from 0 (off) to 12V (on).
Replace R92 with 10k Resistor, put 1k in series from Collector to socket pin. (Current limiter in case of "wrong" patches)
If you short this output/signal it will still mute the internal "slide on" but not doing any other harm.
Same with Q35 for accent. Here change R139 from 100k to 10k. Accent ON has 12V signal.
Nordcore
by antto on Sat Sep 02, 2017 5:27 am
i haven't looked into the schematic right now, but the accent has inverted logic from the sequencer
high means off
antto
by Nordcore on Sat Sep 02, 2017 6:18 am
Q35 acts as inverter, so its that accent output is not inverted.
... but slide will be inverted: use collector of Q30 (with R93 from 100k to 10k) to have a not inverted slide output.
Nordcore
by Paradigm X on Sun Sep 03, 2017 6:26 am
thanks. ill do it when i take my x0x apart
having so much fun jamming tho that this may be a while!
cheers
Paradigm X
