Sokkos 2.0 for Atmega 162 and 2561
Re: Sokkos 2.0 for Atmega 162 and 2561
by donfuego on Thu Jan 02, 2014 2:03 am
What software do I use to flash the firmware from a Mac ?
donfuego
by antto on Thu Jan 02, 2014 10:56 am
for the atmega162 cpu - you can use c0nb0x
antto
by donfuego on Mon Jan 06, 2014 1:32 am
Thanks, that worked great!
Is there any complete documentation on all the functions in Sokkos ?
donfuego
by kroffe on Tue Jan 07, 2014 7:07 pm
donfuego wrote:Thanks, that worked great!
This pretty much sums it up:
http://media.djmania.es/manuales/pdf/Mo ... 20(english).pdf
the rest (2.0 update features) is listed in first post here:
viewtopic.php?f=13&t=19336
kroffe
by human fly on Sun Feb 02, 2014 5:45 am
darffader wrote:
Pish wrote:Are you taking requests?
Any chance that the midi coming out is that same as the CV out. Eg include slide.
Cheers
You cant "slide" with midi
midi is note based, note on, note off.. thats all it can do.
A crazy possibility is using pitch bends but...
have wondered about sending a portamento on/off message :)
early! :) (or would that be late?)
human fly
by nexxyz on Thu Feb 06, 2014 4:14 am
Sorry if this is the wrong way of submitting suggestions, please redirect me if they are appropriate somewhere else or this has already been answered.
I'd like to sync up my Korg monotribe to my x0xb0x via miditribe. However, since the monotribe uses 12p instead of 24p, the monotribe is limited to half a bar, and the "half tempo" option of the monotribe does not affect the playback speed when synced via MIDI.
Is there any chance of a midi clock multiplier/divider option for MIDI Clock Out for such use-cases for the future?
nexxyz
by rv0 on Thu Feb 06, 2014 7:40 am
nexxyz wrote:Sorry if this is the wrong way of submitting suggestions, please redirect me if they are appropriate somewhere else or this has already been answered.
actually the monotribe does use 24p, but its only 8 steps, with steps messed in in between to make it 16 steps ;)
n0nx0x2 has a mode to use pins of the 2561 cpu to output triggers, which effectively syncs a monotribe, a similar trick should be possible in sokkos (when you use the 2561 cpu). In n0nx0x you can choose the amount of pulses sent out so it could be half speed, double speed, etc..
note: this is when sending clock pulses straight from free pins of the cpu, has nothing to do with midi, and you dont need miditribe for it, just the basic sync I/O of the monotribe
rv0
by geux on Fri Mar 28, 2014 7:33 am
Just to say that I've upgraded mine x0x with sokkOS 2.0 really fine with c0nb0x utility.
So THX really much Sokkan and Antto ! :D
geux
by human fly on Sat May 31, 2014 4:39 pm
Cheers
what about sending a portamento on/off message:
http://www.gmarts.org/index.php?go=321
nb:?
"Portamento Control
Number: 84
A Portamento Control message (in conjunction with a MIDI note number) is used to indicate the starting note of a portamento (whereby one note slides into the next rather than having the second note immediately follow the first). The slide rate will be set by the Portamento Time (Controller 5), and the current status of the Portamento On/Off (Controller 65) is ignored."
there's #65 portamento(GS) #84 portamento control(GS) #5 portamento time
#84 > is that how the x0x slide works? slide from selected step?
i've never tried sending portamento on messages with MIDI, does it produce
a usable result?
human fly
by cnt on Mon Aug 25, 2014 10:45 am
Is the "fast edit mode" not working in 2.0 anylonger? (replaced by the triplets on/off)
cnt
by cnt on Wed Oct 29, 2014 6:11 pm
Seems like Transpose isn't working in neither Pattern Play or Track Play? I am pushing Down and Up while playing and nothing happens.
cnt
by antto on Wed Oct 29, 2014 7:17 pm
hodling UP or DOWN only shows the current pitch-shift via the keyboard LEDs
to actually change it you have to also press a pitch Key
antto
by Pish on Thu Jan 29, 2015 8:29 pm
Hey,
Is this still going? Any chance of adding stutted effects to this like the n0nx0x2?
Pish
by Tray on Fri Jun 09, 2017 1:49 pm
Hi all,
I am new to xoxbox, but I was curious why I see alot of new xoxbox advertised as running Sokkos 1.9.x instead of Sokkos 2.0?
Just curious if there is some reason why Sokkos 2.0 is not being used by the latest machines?
Also does anyone have a valud link to the full manusl of everything (including the 2.0 changes/fixes)?
(The link in a previous post is dead).
Tray
by antto on Fri Jun 09, 2017 2:13 pm
probably because the stuff gets copy/pasted around, and those people don't actually follow the forums to be aware of the newer version
antto
