xox accent-out to modded 202, how to?
Discuss mods, hacks, tweaks, etc.
Brother303
Post by Brother303 »
Hi folks,
I modded my MC202 with some stuff fro this site : http://www.cykong.com/Synths/Roland%20M ... -Mods3.htm
I did the accent-cv input mod and want to trigger the 202´s accents from my xox.
Wich is the best point in the xox-circuit to take a 5 volt accent trigger signal to trigger the 202´s accent?
R141? Or Q35? Vr4 pin 2?
Please gimme a hint! :wink:
Cheers
Greg
antto
Re: xox accent-out to modded 202, how to?
Post by antto »
accent trigger out
http://forums.adafruit.com/viewtopic.ph ... 08&start=0
note that the control voltage for the accent is inverted (low means accent is ON, high means it's OFF)
Pish
Post by Pish »
Ive done the same MC202 mod.
This would be my dream too! How easy would it be to invert -5 signal to +5?
Pish
Post by Pish »
Brother303
If you manage this please share your work :)
Brother303
Hi guys,
thanks for helping me out. I´ll check q35 and maybe add an inverting op-amp for the trigger.
Gimme a few days, I´ll report how it works...
Best regards
Greg
Brother303
Hi guys,
I can confirm that the middle pin of Q35 is a perfect source for the accent-trigger signal.
Just soldered a wire there and connected it via a 100k-resistor to the "mix in" jack as output-jack for the trigger, that´s it!
:D
Have fun
Greg
Pish
Post by Pish »
Yessssss! But now I want another x0x for this!
Return to “x0xm0dz”
