square wave mod (pw) updated version
by phono on Fri Jul 04, 2008 3:49 pm
updated this now so i've edited this post with the simpler and better version. Audio examples soon
this mod was inspired by the info in this thread
http://www.ladyada.net/forums/viewtopic.php?t=6240
parts needed
100k linear pot
toggle switch
some wire
rather than replacing the resistor on the board i used the parallel resistor method, so first locate where R45 is on the switch side (top side of pcb when x0x is assembled)
solder a wire to each node of the resistor then and attach one lead to the middle leg of your 100k pot. Then take another length of wire and solder one end to either free leg of the 100k pot (depending on which way you want to turn it to increase the amount of pwm. either leg will do) solder the other end of the wire to middle leg of your toggle.
Now take the other wire from the other end of the resistor and solder this to a leg of the switch. Drill some holes in your panel, mount the hardware and you are done :) pretty simple this one
Here's a crude picture of the mod
since we are running in parallel when the circuit is on (switch enabled) we get a resistance range from between 0 and ~18k
pretty simple mod to do since you dont need to remove anything.
updated audio examples to follow (the examples below are from the first version)
x0x #733 Image SH-101 MC-202 TB-303 TR-606 TR-808 TR-909 MKS-50 Juno-106 A-100 Virus-B E-6400 SX-150 Monotron
phono
by phono on Fri Jul 04, 2008 4:00 pm
ok heres the audio,
first here's the stock version without the mod enabled (this is my self sourced x0x)
http://www.bahnhof.se/wb447909/phono/x0 ... _stock.mp3
now here's the mod in the minimum position (~13.5k resistance)
http://www.bahnhof.se/wb447909/phono/x0 ... in_pwm.mp3
now here's the mod in the maximum position (~17.4k resistance)
http://www.bahnhof.se/wb447909/phono/x0 ... ax_pwm.mp3
here's an alternating version so you can hear the differences all in one go, it starts as stock, then min position, max position then stock again etc
http://www.bahnhof.se/wb447909/phono/x0 ... _modes.mp3
now finally here's a demo of the mod wihtout any other knob tweaks, im just sweeping the 50kb up and down, the very last pattern in the sequence is stock for reference
http://www.bahnhof.se/wb447909/phono/x0 ... wn_pwm.mp3
phono
by phono on Fri Jul 04, 2008 4:01 pm
must say im quite pleased with this mod, just waiting for you real 303 owners to comment ;)
phono
by GoldDope on Fri Jul 04, 2008 4:07 pm
Lush :)
sounds lurvely mate,
how come every x0x i hear sounds different,mine sounds different too,
my square sounds very square but your slides between notes seem more vivid.
GoldDope
by phono on Fri Jul 04, 2008 4:09 pm
GoldDope wrote:Lush :)
probably the same reason no two 303s sound the same :wink: x0x#733 sounds slightly differnt to the self sourced also, but i did the tm6 tweak on her also :)
phono
by Computer Controlled on Fri Jul 04, 2008 4:13 pm
Sounds pretty good. I'll have to do this to mine and do the comparisons that way to make a real informed judgment. What side of the pot did you wire the switch to? I'm assuming the fully clockwise side?
Synths: SH-1 . SH-101 . TB-303 . JX-3P . x0xb0x . uWave II . Alesis Ion . Pro-One w/Synthwood case . MoPho . Monotron
Drum Machines: TR-707 . R-70 . E-MU Procussion
Computer Controlled
by phono on Fri Jul 04, 2008 4:19 pm
it doesnt really matter actually, but i think just like van gogh picture :lol:
phono
by phono on Fri Jul 04, 2008 4:24 pm
starting to get crowded on teh back panel 8)
phono
by GoldDope on Fri Jul 04, 2008 4:50 pm
Phono can you do me a pic of your bass boost mod,.
and whats te mome swicth ? is it the same res mod i have ?
GoldDope
by hamburgers on Fri Jul 04, 2008 4:55 pm
GoldDope wrote:whats te mome swicth ?
i show up at your door and kick your shins off
hamburgers
by phono on Fri Jul 04, 2008 5:21 pm
yeah im too scared to use that one :lol:
phono
by Computer Controlled on Fri Jul 04, 2008 5:50 pm
Haha =o]
Computer Controlled
by Computer Controlled on Fri Jul 04, 2008 5:51 pm
Go figure, Rat Shack didn't have any of the parts i need. Now i gotsta order them!
Computer Controlled
by phono on Fri Jul 04, 2008 6:05 pm
GoldDope wrote:Phono can you do me a pic of your bass boost mod,.
phono
by Computer Controlled on Fri Jul 04, 2008 6:15 pm
I'm curious what you used to cut your holes in the back panel.
Computer Controlled
