Re: trying to put new firmware on mode machines xoxbox
by antto on Mon Nov 02, 2015 2:53 pm
if the firmware works - it has been flashed
i assume you are looking at what c0nb0x displays when you connect to the firmware afterwards..
when you connect to the firmware with c0nb0x, it tries to distinguish what firmware it is, but this is done using new messages which c0nb0x introduces into the protocol, and most firmwares (especially those which run on the atmega162) don't support them
as a result, c0nb0x cannot tell what the FW is, so it would print something like "(auto) Adafruit 1.05 compatible"
but if you flash sokkos2, and the x0xb0x works - you have succesifully flashed sokkos2
hope this helps
