Dear Ladyada,
I recently ordered two boards - an ADIO and the Sensor board. The ADIO works a treat and i've just set up an infrared sensor (one with a wider range up to 120cm) and i'm over the moon with it - ansolutley amazing/!!!!! But! the Sensor board for resistive sensors won't work...
The green power light comes on. The red/green led flashes green - it's sending midi. My UM EX 1 edirol midi to usb converter flashes to say it recieving midi. The audio setup on my mac book pro sends a test signal to say midi is being sent and received. But, the midisense software (which works great with the ADIO board states that it has failed to find any midisense boards when i try to connect to the sensor board. I've checked all my solder points - no cold joints etc. What could the problem be? Hope you can help. Ben
MidiSense Board Not recognised by midisense software
MIDISense Board Not recognised - Part 2
Strange isn't it that one works (ADIO) and one doesn't....
Could it be the R3 and R6 resistors? I found the build instructions for these are a little bit confusing.... Here's the resistors i thought the instructions were telling me to use:
R3 220 ohm
R6 220 ohm
R7 10k ( the instructions don't seem to say which one to use - i used the one i had left...)
R13 220 ohm
If these are wrong it should work if i put the right ones in!
Thanks for your help with this,
Benjamin Freeth
R3 220 ohm
R6 220 ohm
R13 220 ohm
Benjamin Freeth
Wrong Value Resistors Used
Can you clarify which resistors should be used in the following positions:
R3, R6, R7, R13?
Thanks,
B
R3, R6, R7, R13?
Thanks,
B
Re: Wrong Value Resistors Used
same error here! my debug log shows the same error as in this thread: http://forums.ladyada.net/viewtopic.php?t=5116, but the oszi is right, 16Mhz.humanpyramid wrote:Can you clarify which resistors should be used in the following positions:
R3, R6, R7, R13?
Thanks,
B
R13=1k
R10=10k
this information is from the build instruction side. Also noted there:
>Note: there was a PCB error in some very early MIDIsense resistive
>boards, R3 and R6 may be swapped! Check that the 220 ohm resistor
>connects to the MIDI jack and the ~1.5K resistor connects to the bi-color
>LED.
What early boards? I just mounted as instructed (i did not switch r3 and r6)
R3=220Ohm
I also noticed, R3 and R6 are swapped in those 2 pics!
ok i swapped R3 and R6 - still the same error. I looks like midisense dont receieve data (red blink), even if th midi controller sends data, according to its led. Ill guess i will have a look tomorrow with my voltmeter...
some quick information:
-usb drivers are ok, tested with midiox
-midi cables are not reversed
-soldering should be fine, as i double checked it
-green led is blinking, red led is only blinking when using midiox
Ok i read the instructions again:
red-red-brown 220Ohm - connect to midi jack - r3
brown-black-red 1kOhm - connect to bi-color led - r6 connects to led
so i switched back the resistors...
then
-Make sure the amtel sits tight on the socket (mine wasn't really tight)
-i set dip-switch 1 and 2 to on
-there are no drivers from the manufactor (midi sonic 2x2, infrasonic)
Using Win XP SP2, I could connect to the device! I was unable to connect using Windows Vista SP1 (I also tried to "runas administrator")!
There were some errors in the connection:
I started to verify the firmware... and canceled this procedure... NOW my midisense board act's "funny", when i power it on, the led flashes once red (guess this means that the bootloader should be fine), but the led does not flash green anymore! I guess when the bootloader works, it should be possible to upload a new firmware... or not?
so - in other wordsCheck that the 220 ohm resistor connects to the MIDI jack and the ~1.5K
resistor connects to the bi-color LED.
then
00000043 19.19594955 [6476] 22:48:09: adding checkboxes
00000044 19.19656754 [6476] 22:48:09: adding names
00000045 19.21066666 [6476] 22:48:09: adding typechoice
00000046 19.25665092 [6476] 22:48:09: adding new panel: 13
00000047 19.37583733 [6476] 22:48:09: MIDI error: PortMidi: 'Buffer overflow'
00000048 20.18521881 [6476] 22:48:10: Done
00000049 20.18528557 [6476] 22:48:10: Found 1 boards
00000050 20.18531990 [6476] 22:48:10: Configuring board #13
00000051 20.21488380 [6476] 22:48:10: Sending Packet: 0xf0 0x7d 0x20 0xd 0x0 0xf7
00000052 21.23618507 [6476] 22:48:11: Sending Packet: 0xf0 0x7d 0x20 0xd 0x0 0xf7
00000053 21.66623878 [6476] 22:48:11: ***************Recv'd bad checksum: 16 sum = 86
00000054 21.66629791 [6476] 22:48:11: Recv'd Sysex: 0xf0 0x69 0x21 0xd 0x3f 0x10 0xf7
00000055 21.66631126 [6476] 22:48:11: enabling sensors 0x3f
00000056 21.67483521 [6476] 22:48:11: stop
00000057 21.67488861 [6476] 22:48:11: Started Listening
00000058 21.67504120 [6476] 22:48:11: Sensor 0
00000059 21.68149757 [6476] 22:48:11: Sending Packet: 0xf0 0x7d 0x32 0xd 0x0 0x0 0xf7
00000060 22.01914406 [6476] 22:48:12: Sending Packet: 0xf0 0x7d 0x10 0xd 0x1 0x0 0xf7
00000061 22.44915390 [6476] 22:48:12: MIDI error: PortMidi: 'Buffer overflow'
00000062 23.35701180 [6476] 22:48:13: Sending Packet: 0xf0 0x7d 0x10 0xd 0x1 0x0 0xf7
OK it looks like I was right about updating the firmware...
But after erasing the eeprom, midisense crashed:
ARGH.. any hints?
EDIT:
after erasing flash, midisense lost connection to the board. after i confirmed this message, midisense tries to program addres #0 - and crashes. the same error occurs trying to verify the fw. this looks like a bug of midisense...
I also noticed that the flash process needs allmost 100% of my cpu!
Ahh, I guess a warning message should be displayed, that verify firmware should not be interrupted, or the fw could get damaged!
[7016] 23:24:28: Sending Packet: 0xf0 0x7d 0x44 0x1b 0xf7
[7016] 23:24:28: sent
[7016] 23:24:28: bootloader, skip checksum
[7016] 23:24:28: Recv'd Sysex: 0xf0 0x7d 0x33 0x9f
[7016] 23:24:28: Got reply, 0 bytes
[7016] 23:24:30: timeout
[7016] 23:24:30: Sending Packet: 0xf0 0x7d 0x44 0x1b 0xf7
[7016] 23:24:30: sent
[7016] 23:24:30: bootloader, skip checksum
[7016] 23:24:30: Recv'd Sysex: 0xf0 0x7d 0x33 0x9f
[7016] 23:24:30: Got reply, 0 bytes
[7016] 23:24:30: look for reply
[7016] 23:24:30: eek!
EDIT:
yes, another message, ill talk to myself ... i guess the problem is this f3$!@g usb-to-midi adapter, which comes without driver and manual, thats why the performance is that bad (>90% cpu use of midisense).. just and idea. anyone tried allready this adapter: http://www.infra-sonic.com/page/midisonic.html ?
ok, i stopped all cpu intensive tasks (wlan services, virus scanners etc..) and then I retried it. Uploading the firmware is quite timing relevant, if i started midisense too early, i received alot timeouts, after some tries, the firmware upload went fine. after uploading the firmware successfully, midisense tries to verify the firmware. at verifying adress 64 (or 128) midisense just freeze, no error is displayed in gui or in debugview... any hints here?
Ok I just realized, that vista is not supported due the portmidi lib. we use quite an old version here (15 nov 04), check the changelog:
http://portmedia.svn.sourceforge.net/vi ... iew=markup
So i created an up-to date version of midisense. I also created a version, which does not verify the firmware and a version with an larger timeout (6s).
Ill test this this evening... cheers
