Charging problems
Charging problems
by Ryint on Mon Jan 02, 2017 6:44 pm
This is my second mintyboost build but for some reason the charging logo on my devices appears but the batteries drain instead of charge. Tried with fresh batteries on a Huawei p9 and iPad mini with no luck. Checked and double checked the board and there's no cold joints or shorts.
Any suggestions would be great.
Topside
Bottomside
Ryint
Re: Charging problems
by adafruit_support_bill on Tue Jan 03, 2017 6:53 am
Not sure about the charge current requirements of the Huawei, but I believe that the iPad Mini needs at least 1A and the MintyBoost is only capable of sustaining 500mA.
by Ryint on Mon Jan 09, 2017 12:48 pm
I've since tried it with some older devices that worked fine with my first build and still had no luck. Could it maybe be a USB spec thing?
Ryint
by adafruit_support_bill on Mon Jan 09, 2017 1:28 pm
Check to make sure that the output is steady and close to 5v. Also check the voltages on the two data pins.
