📣📪 🚚 Adafruit will not be shipping USPS orders Monday January 20, 2020 🗓. Expedited USPS orders placed after 11am ET 🕚 Friday January 17 will go out Tuesday January 21 📣📪🚚
MintyBoost v3
MintyBoost v3
by charlie5210 on Mon Dec 04, 2017 11:06 pm
I Built the kit a while back and it didn't work but I've came back to it trying to see what I did wrong. If anyone could help me figure out what I might of did wrong it would help a lot thanks. :D
charlie5210
Re: MintyBoost v3
by adafruit_support_bill on Tue Dec 05, 2017 6:50 am
The assembly looks good from what we can see. What are you using to power it? When powered, what voltage are you seeing at the output?
Re: MintyBoost v3
by charlie5210 on Tue Dec 05, 2017 9:02 am
I’m using the included AA Holder with 2 Alkaline battery’s that are both 1.5v. I don’t have a tool right now to measure the voltage of it.
charlie5210
Re: MintyBoost v3
by adafruit_support_bill on Tue Dec 05, 2017 9:13 am
Looking closer at the photo, there are a couple of solder joints that look like they may not have flowed well onto the solder pad. You also have one resistor connection where the solder did not wet the lead wire. This guide has some tips on identifying and fixing common problems such as these: https://learn.adafruit.com/adafruit-gui ... n-problems
Other than that, we'll probably need to get some voltage measurements to diagnose the problem.
Re: MintyBoost v3
by charlie5210 on Tue Dec 05, 2017 9:26 am
Ok thanks I’ll try to get some voltage tests later
charlie5210
