Pre- Completion Test - Hot chip
by gettothechoppa on Sat Jun 16, 2018 1:35 pm
Hi guys,
I've recently tried to build one of these Mintyboost thingies but when plugging the chip in [notch up etc], it get super hot within a second or so.
Checked continuity and count ten points on the ground which seems to make sense from the shematic.....
Pictures of the back attached if somebody could help me!
gettothechoppa
Re: Pre- Completion Test - Hot chip
by franklin97355 on Sat Jun 16, 2018 1:41 pm
Some of your solders could use a touch-up but there don't seem to be any shorts. Take a look at this Soldering Guide for some help. Can you post a picture of the other side?
franklin97355
by gettothechoppa on Sun Jun 17, 2018 4:26 am
Of course, thanks for your help!
Do those poor soldering joints means that there could be a short somewhere? I can't theoretically figure out why the chip would be getting so hot hmmm...
Any ideas why that would be the case?
I'm reluctant to start blaming the components before I blame my skills lol!
Thanks,
Alun.
file (1).jpeg (848.33 KiB) Viewed 750 times
gettothechoppa
by gettothechoppa on Sun Jun 17, 2018 4:31 am
I'm suspicious that the solder joint on the resistor under the IC casing is causing a short - from the picture what do you think?
gettothechoppa
by franklin97355 on Sun Jun 17, 2018 1:33 pm
It could be. The solder didn't flow completely and I'm not sure where that wire out the top of the solder goes but it looks like it is keeping the socket from fully seating on the board.
franklin97355
