Not working at all
GMunroe998
Not working at all
Post by GMunroe998 »
Ok mintyboost is not working at all. Tried the chip one way it got ridiculously hot. Tried it the other way it did not, both ways did not charge the iPhone 5. What did I do wrong? All the solder points were well done. The way I see it something must be backwards But there we two things that resemble resistors left over and not included in the instructions. What did I do
ifrpilot999
Re: Not working at all
Post by ifrpilot999 »
It looks like the red (normally +) wire is soldered to the neg pad on the MintyBoost. And likewise, the black (normally -) wire is on the positive pad on the MB. The battery is reversed going into the MB.
GMunroe998
Yeah that's my fault. After the chip got crazy hot I switched them. I just forgot to switch them back before I took the picture.
jke
Post by jke »
The capacitors are wrong and need to be turned around (the white stripe at the side = minus/negative). Just de-solder them and turn them 180° around so that the negative pole corresponds with what is printed on the pcb.
Else, the rest looks fine (except of course for the cables).
adafruit_support_rick
Be careful unsoldering the electrolytic caps. It's easy to melt the guts inside the cans if you heat them for too long.
There is a test in the assembly instructions, right before you install the USB socket. Did you do that test? Then would have been the time to stop and look for the problem. Hopefully, you haven't damaged anything by reversing the power leads and the boost converter chip.
Return to “MintyBoost”
