minty boost
minty boost
my lt1302 ic has internal connection on 7th pin and 8th pin is that supposed to be correct or what?
- adafruit_support_rick
Re: minty boost
No. There should be no short between the pins. Is that what you're seeing? Did you check this with the chip still installed in the socket, or did you remove the chip first?
Re: minty boost
ya i removed the chip from socket and checked .btw tks for quick reply..has the ic been damaged or what?
Re: minty boost
Sounds like it's burned out. According to the block diagram in the datasheet, there's supposed to be a transistor between those two pins.
Re: minty boost
thank you i think i should order a new one.btw awesome project
