Wind turbine to mintyboost lipo instead of solar
by DaddioPlus on Thu Oct 31, 2013 1:57 am
Has anyone used a small wind turbine to charge the lipo battery in a mintyboost (like the hand-bag) instead of using the solar panel. For that matter could you use both. I am wanting to charge my phone over night on camping trips and would like a backup to the solar.
I have seen the posts about making sure there is a diode in the setup, so I assume it was tried. But could not find if anyone has done it.
DaddioPlus
Re: Wind turbine to mintyboost lipo instead of solar
by adafruit_support_bill on Thu Oct 31, 2013 5:50 am
You also want to make sure that your turbine output voltage does not exceed the rating of the LiPo charger.
by DaddioPlus on Thu Oct 31, 2013 8:56 am
I would need to keep the source (wind turbine) regulated to 6V 3.4W, or as close to the solar panel output as possible.
DaddioPlus
by adafruit_support_bill on Thu Oct 31, 2013 9:16 am
The voltage is what you need to regulate. The watts depends on how much current is drawn by the load. (In this case the charger)
