Black Lives Matter - Action and Equality. ... Adafruit is part of the Stop Hate for Profit campaign. Adafruit is open and shipping.
6vdc Lantern Battery - MintyBoost
by cewmjtm on Fri Feb 05, 2016 11:54 pm
What if any modifications would need to be preformed if I wanted to utilize a 6vdc Lantern Battery as the power supply for Minty Boost? I am looking to build a unit that I could use in an emergency event, and one that may be able to recharge an Iphone multiple times
cewmjtm
Re: 6vdc Lantern Battery - MintyBoost
by adafruit_support_bill on Sat Feb 06, 2016 7:30 am
The maximum input for the MintyBoost is 5v. Since 6v is higher than 5v, what you need is a 'buck' converter, not a 'boost' converter. We have the UBEC, which can take v or more and convert it to 5v: https://www.adafruit.com/products/1385
And there is also the 'Verter' which can do both buck and boost conversion. This gives you the most flexibility in power-supplies.
https://www.adafruit.com/products/2190
by cewmjtm on Tue Feb 16, 2016 1:46 am
if I understand the desc, it appears that the "verter" power supply is all I need (besides the USB connector) for a 6vdc lantern battery / iphone charger .. I can use the Mintybost in its original config as a separate unit, correct?
cewmjtm
by adafruit_support_bill on Tue Feb 16, 2016 7:13 am
That is correct. You can plug your phone (or other USB device) directly into the Verter.
