Battery Example Size
by vitaminmoo on Thu May 14, 2009 12:09 am
Is it just me, or is the battery linked in make (http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=1086) actually too big for this application? It looks to me like it will overlap all four standoffs.
vitaminmoo
Re: Battery Example Size
by Wrhector on Thu May 14, 2009 7:55 am
Heh, I noticed that. The only decent one which looks like it would fit was this:
https://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=4357
There's one with a built in PCB but that is too long so you have to put the PCB at the side. Same circuit protection board for other battery will work for this.
Wrhector
by antares on Thu May 14, 2009 4:11 pm
That's no news:
There's already a thread about it.
antares
by andyman on Thu Aug 27, 2009 4:05 am
A perfect battery for your application is a ThunderPower Pro lite 1320mah battery. If you buy the TP1320-2SPL, all you need to do is modify the battery to be in a parallel configuration giving you 3.7V @ 2640mah capacity. Thunderpower batteries are proven to last a long time compared to generic batteries and have a discharge rate of 13C. It will also survive hunders of charge cycles other batteries may not.
Plus this particular battery fits perfectly in the wave bubble.
http://thunderpowerrc.com/html/battery/prolite_1320.html
andyman
