Can't get a sweeping 16 kHz square wave output
by san26141 on Thu Jun 25, 2009 7:27 pm
I am stuck in the Analog/Digital tuning section of the build. I have been able to run the test_led (although it doesn't blink once/sec?) but I am having problems with the PWM test (test_DC).
I probe the L5 & L6 input and I get a sweeping 2 kHz squarewave not the 16 kHz as in the build instructions.
The ucontroller is the atmega88 with the Avrisp MKII and I'm using Avr studio4 with avr_gcc.
Thanks for any help you can give me.
D
san26141
Re: Can't get a sweeping 16 kHz square wave output
by nux on Thu Jun 25, 2009 10:53 pm
Sounds like you have not programmed your fuses correctly, the AVR may have the divide by eight clock divider set.
Although, I could not get a square wave output to display on my scope when I was testing that section, but all subsequent sections worked.
nux
by san26141 on Fri Jun 26, 2009 7:12 pm
That was it....the divide by 8 was set. Unchecked it and burned it again and it worked.
san26141
