Loading the Firmware Atmega88 for the wave bubble
by ballistic on Sat Aug 15, 2009 3:15 am
When loading firmware into the Atmeg88 i get to burn the fuses ok, however, on the second attempt to load any of the firmware, the chip will not power on anymore. I have managed to stuff 5 of these so far! What is happening? all my power supplies are correct, hardware that i am using, is the USB ISP Programmer for ATMEL AVR (ATMega/ATTiny...)
and the software i have tried is either WinAVR20090313 or Extream burner - AVR.
What combinations of hardware and software work well?
Do you need to burn fuses each time you do a write to the chip?
Please HELP!
Other that this $#@%^ of a problem, the project is going well.
Cheers
Steve
Problem solved, used a Atmel programmer with Atmel software, the project continues.
ballistic
cron
