PLL Help
PLL Help
by grapeape on Sat Sep 19, 2009 1:17 pm
Hi All,
I've been building and testing for some time and am having difficulty with the PLL stage. When I program test_pll1() I am seeing a 5Hz wave on pin 10, where the documentation indicates I should be seeing 1Hz. The crystal is being driven correctly and the regulator is working. Any thoughts?
Attempting to tune a program generates the "RF VCO range is too low!" message, which would suggest that my PLL isn't functioning.
Cheers,
John
grapeape
Re: PLL Help
by grapeape on Mon Sep 21, 2009 11:59 am
Can anyone think of further tests to isolate the problem? I'm really quite lost at this point.
grapeape
Re: PLL Help
by Buggy222 on Sun Nov 29, 2009 1:03 am
On the laydada webpage follow the Wiki link and look at the "Make" link, and then the PLL. You will see a notation that the frequency will be 5 not 1.
http://ladyada.net/wiki/wavebubble/pll
PLL Notes
when running the test_pll1 code. the rc1a firmware will set Ftest(pin 10) to 5hz (not 1hz as per the pll docs).
Buggy222
Re: PLL Help
by grapeape on Thu Jan 14, 2010 7:23 am
Thanks Buggy. Not sure how I missed that note.
Is there a good reference around for debugging the PLL stage? I've been stuck here for quite a while. While the PLL section of the Make pages describes the tests to verify functionality along the way, it doesn't offer much help when one of the tests fails.
grapeape
Re: PLL Help
by Bandit on Wed Feb 17, 2010 7:22 pm
Did you get the other PLL test programs working? Im having problems with those, when I probe the middle of the two resistors for each stage as directed. Im not getting the switch over between around 0V and 2.1V :(
Bandit
Re: PLL Help
by c.b. on Thu Feb 18, 2010 11:14 am
Hi Bandit,
I had problems, too, at that stage. I had forgotten to solder the resistor that connects the VCO's outputs to the PLL chip. Some HF went to the PLL chip through the air or I don't know how, anyway sometimes the PLL output flipped and sometimes not.
c.b.
Re: PLL Help
by Bandit on Fri Feb 19, 2010 9:49 am
I thought that might be the case so I placed some copper tape over the gap in the track. I would have thought some of the signal would be coupled throught both the air and the FR4 substrate, moreso through the substrate. I'll try putting the resistors on. Thanks.
Bandit
