Ok,looking at my PCBs (from buzz) and its becoming apparent that all the parts placements on the PCB are wrong..
Or are they!!!
Now, my gut instinct says that the pdf files are likely to be correct, but i'd just like to confirm this.
Ive included images for reference and to illustrate my point.
So looking at the 3.3v regulator and those 2 surrounding caps, on the PDF they are C2 C7 & IC1 but, on my PCB they are C17, C21 &IC10.
Most of the component placings on the PCB appear to be wrong.
So, just to confirm, the PDFs are the ones i should use???
Thanks.
Parts Placement on PCB VS PDF.
Re: Parts Placement on PCB VS PDF.
here is what your pdf looks like as an overlay on the board if that helps
http://imagebin.org/138434
- cornz
Hi, that helps but its not quite what i meant.
Look at IC1 in the bottom left of the PDF, now, look at my PCB, IC1 is marked IC10. I wanted to make sure it was the PDF placement guide i should follow and not my PCB.
