๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday January 20, 2020 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday January 17 will go out Tuesday January 21 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
Little Help?
Little Help?
by vac on Mon Jun 24, 2013 9:53 pm
Long time lurker, just finished my wavebubble 2010b and it works for the most part but only when I immediately program it utilizing the menu over the usb/serial connection. It does not store the tuning information for jamming following a power cycle and if it's not in the programming menu over usb/serial, I cannot get it to turn off either. Powering on without being in the programming menu results in a solid green led and the inability to turn itself off. It works fine otherwise and does the business but again, only while it's in the menu. Currently at a loss as to what the heck is causing it to act like this. Replaced all transistors and programmed it using the following settings:
avrdude -c usbtiny -p m168 -P usb -U lfuse:w:0xe2:m -U hfuse:w:0xd5:m -U efuse:w:0xf9:m
avrdude -c usbtiny -p m168 -P usb -U flash:w:main.hex
Any and all help is greatly appreciated.
Thanks in advance,
-Vac
vac
Re: Little Help?
by lightningserpent on Mon Jun 24, 2013 11:44 pm
I would guess there is a short in one of the communication pins on the FTDI chip and/or the ATmega pins. Maybe one of the pins is being held high(or low) and preventing the wave bubble from operating properly.
lightningserpent
Re: Little Help?
by mandy on Fri Jul 12, 2013 3:25 pm
Hi vac!
I have just seen your post and I have exactly the same issue with my WB. Its only working properly when being in the terminal menu. Have you been able to fix this problem?
Many thanks,
Mandy
mandy
Re: Little Help?
by vac on Sat Jul 13, 2013 12:31 pm
Sadly no, I've been too busy these past few weeks and haven't had the time to troubleshoot the damn thing. I did, however find this thread helpful even though I haven't had the chance to test it out myself. Does your led on the main board stay solid if you try to run it disconnected from usb? I'm 90% certain our problem is that we borked the programming somewhere and the thing is stuck in reset.
vac
Re: Little Help?
by mandy on Sat Jul 13, 2013 4:19 pm
Hi vac,
basically, yes - the LED is constantly on when powered and disconnected from USB. In this state I cannot power it off or select any program via S1. To power off I short out the RST to GND on the ISP header. However, I did a few more tests today with an oscilloscope and I found that there is constant traffic on the TX and RX lines on JP1 when I switch on. I don't know yet what this traffic is but this traffic is the reason why in my case I cannot operate the bubble normally. Because of this traffic the wavebubble gets the message that someone must have pressed a key and it therefore enters its menu, i.e. the LED is constantly on and it can not be powered off via S1. To avoid this situation I can short the TX to GND on JP1 during switch on. The traffic on TX stops and the switch on works and the LED starts blinking and runs the program as I can see on the spectrum analyser. So all in all I'm a step further today although I'm not sure where it leads me. I guess next is to understand what is going on on the TX-Pin during switch on when no USB cable is connected. If the cable is connected I dont have this traffic on the TX pin. Very strange the whole issue... :?
That's all for now,
Mandy
mandy
Re: Little Help?
by extratitanian on Wed Jul 24, 2013 5:21 pm
What programmer are you using to upload the code? I think i've gotta get a new one and figure I'll go with a known good setup.
extratitanian
Re: Little Help?
by vac on Sun Aug 04, 2013 7:17 pm
I used the USB-tiny kit from the adafruit store as well as the Bus Pirate for some troubleshooting. USB-tiny is a lot easier and doesn't require a patched AVRdude in order to run but either will work.
vac
Re: Little Help?
by RHouts on Mon Aug 08, 2016 10:18 pm
I do not know how to post a new thread but I am in need of a little help.
I would like to power up to 8 raspberry pi boards and I was wondering if I am able to do so with a power relay. I will have a power socket connected to the power relay and also connect the RPi3. Please let me know if this is possible.
RHouts
