Hello!
I've embarked on the assembly of my wavebubble, and I'm about to solder the battery/protection circuitry on. However, it is not immediately obvious how the protection circuit is supposed to attach to the battery. I'm using the stock parts reccomended in the build manual, so I'm hoping that someone else will have had experience with this.
The protection circuit is a little long to go between the battery contacts - should i just figure out a way to goop some solder on there, or is there a more elegant solution?
Battery protection circuit too long?
Look through this post. You can see two ways I mounted the board.
http://www.ladyada.net/forums/viewtopic.php?t=3592
